Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Power/Renewable Energy/EV's
How to test an IR2104/2111?
« previous
next »
Print
Search
Pages:
Prev
1
2
All
Go Down
Author
Topic: How to test an IR2104/2111? (Read 7672 times)
wraper
Supporter
Country:
Re: How to test an IR2104/2111?
Reply #25 on:
April 21, 2024, 05:22:05 pm »
Looks working fine.
Logged
DELTA67
Regular Contributor
Country:
Reply #26 on:
April 21, 2024, 06:55:02 pm »
Quote from: wraper on April 21, 2024, 05:22:05 pm
Looks working fine.
Yes, the only downside in the DC test is that the HO output of the IR2104 don't goes low down to 0V. the low level of this output is about 3V.
in the AC test there's no signal at this output as I said before (it stays high or low, I don't remember the measurement I've done) .
Logged
mtwieg
Regular Contributor
Country:
Reply #27 on:
April 23, 2024, 12:26:05 pm »
Something is still wrong with the IR2104 then. Its outputs should pull strongly all the way down to ~0V.
If you tie SD to GND, does that cause both outputs to pull low?
Logged
Print
Search
Pages:
Prev
1
2
All
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
