Author Topic: Flyback stability by increasing upper divider resistor?  (Read 1911 times)
Offline FaringdonTopic starter
« on: January 22, 2024, 09:34:48 pm »
If you are doing offline flyback  with  the lowest component count feedback loop, then you are doing
it like in the attached with TL431.
Output caps are 2 x 35ZLJ330's by Rubycon.
These have  tan delta = 0.12 at 120Hz. This would mean ESR  of some 0.48 Ohms at 120Hz.
From post #11 of this
https://www.edaboard.com/threads/calculate-esr-of-electrolytic-capacitor-over-frequency-sweep.407674/
Its pretty obvious that the actual ESR of the 35ZLJ330 at 120Hz is going to be around 0.18 Ohms or so.
Nothing like as high as 0.48 Ohms.
Now , low Capacitor ESR is the biggest threat to stability of the shown flyback. So a good way of calculating ESR is needed.
However, this is not to be found.
Instead we are left with simply having to increase the Ohmic value of the upper divider resistor in order to increase phase margin (and simultaneously increase lower divider resistor
so output stays at 24V).
So how many people (who use the attached schem) simply up the divider resistor in order to increase phase margin in the face of the onset of future electrolytic caps
with ever decreasing ESR?
Rubycon ZLJ 'lytic caps
https://www.mouser.co.uk/datasheet/2/977/e_ZLJ-1601167.pdf
« Last Edit: January 22, 2024, 09:37:33 pm by Faringdon »
'Perfection' is the enemy of 'perfectly satisfactory'
Offline jonpaul
Re: Flyback stability by increasing upper divider resistor?
« Reply #1 on: January 26, 2024, 11:08:22 am »
FTSS: usual garbage, get a life
j
Jean-Paul  the Internet Dinosaur
The following users thanked this post: Faringdon
Offline multipla
« Reply #2 on: January 31, 2024, 08:47:30 am »
wrong.
