So, you wish to design and test an offline , Current mode Flyback. You want it to be stable with any opto with nominal CTR between 50% and 600%. The flyback is in CCM at low mains, with max of 0.57 Duty cycle, and DCM at high mains.
But when you buy an opto, you can only buy say “50 to 600%” or say “160 to 320%”, or say “300 to 600%” , or “40 to 80%”.
So how do you guarantee that you actually test your flyback with a nominal 50% (or less) opto, and also a nominal 600% (or more) opto?
..The answer is that you buy two “300 to 600%” opto’s, and put them in the test circuit 1 attached.
You then test that for stability.
You then buy one “40 to 80%” opto, and put it in the circuit 3 attached, and check for stability.
Would you agree, this is the best method?
(LTspice and PDF attached)
