If i am using MCP1630 and want a 0.33V current limit (instead of the 0.9v), then may i just feed the COMP pin from the output of an opamp with 1V at non-inv and diode from COMP to opamp output, and negative feedback from COMP to opamp neg input? (as per attached)
