I just started to design my off grid home system.
Since my power company does not support net metering and for other reasons, I think it will be best for me to put in place a off grid energy storage system, PV Panels and use the grid only if necessary (battery low or home asking for too much power).
I would like to use two
Victron Energy Quattro 10KVA 120VAC wired up in a split phase configuration.
Yes, I am located in USA.
Now I need some battery, and I am temped (looking at the costs) to build my own 16S packs starting with 3.2V LiFePO4 cells.
Specs:
- >100AH, 200AH preferred
- M8 screw terminal connectors
Since most of the batteries are made in China, I would have no problem to buy on the www in Aliexpress or so, but I am worried not only about lemons (should not be the case), but to get bitten by the slow supply chain.
On top of that I need a good BMS system.
1 - Can you point me to a good battery shop? China or USA?
2- What would be a good BMS system for that?I have a
TTi QPX1200SP and a
TTi LD400P to perform some experiments to understand if the cells are good or not. Plus some 6.5 bench DMM.
Many thanks in advance for all your help.
