Author Topic: buck feedback - should trigger what change?  (Read 860 times)
Offline mikeinfodocTopic starter
« on: May 17, 2020, 12:12:05 pm »
if I have a feedback network on a buck circuit (such as a voltage feedback)...
Should/would it generally want to trigger a change in :
  • Frequency? ...or...
  • Duty Cycle?
In other words, would it be better to adjust duty cycle? or frequency? (of pwm) in order to adjust output voltage?
Offline David Hess
  • DavidH
Re: buck feedback - should trigger what change?
« Reply #1 on: May 18, 2020, 02:19:32 pm »
Either can be used.  Common switching regulators vary their duty cycle to control the output but constant off-time switching regulators like the old 78S40 instead effectively alter their frequency.  Both methods of operation have their virtues.
