Author Topic: Buck output capacitor selection  (Read 1344 times)
Offline mikeinfodocTopic starter
« on: May 17, 2020, 12:16:57 pm »
If I want to plan a buck circuit with a 100uF output/bypass cap,
 what type of capacitor would be good for a buck?
The reason I ask, is because the ONLY cap's I have on my shelf >=100uF is electrolytic capacitors.
I wanted to see if those types would be ok in a buck circuit...
if not, I welcome recommendations.
Offline Styno
  • TÜV-geprüft
Re: Buck output capacitor selection
« Reply #1 on: May 18, 2020, 07:25:00 am »
What does the datasheet of the buck say about the requirements for the output cap?
« Reply #2 on: May 18, 2020, 09:49:25 pm »
In my case, I hope to begin building some buck circuits FROM SCRATCH for learning and testing.
So for example, I thought of starting with a 12V input, and a 5V output (which might eventually serve as a usb charger).
I realize newer devices can pull >2A,
but for my first buck circuit/test, I will just us a simple a resistor as a load, and would plan to initially draw <500 mA.
Offline ahbushnell
« Reply #3 on: May 18, 2020, 11:50:40 pm »
I'm glad your interested in getting into power electronics.  I suggest doing some reading on the subject.  I suggest:
Switchmode Power Supply Handbook by Keith Billings.  I have the second edition but there may be a newer version.  There are other books on the subject.
Also Texas Instruments has man ap notes that are very useful.
Andy
Offline David Hess
  • DavidH
« Reply #4 on: May 19, 2020, 01:19:58 am »
The output capacitance is not as important as the impedance and ripple current rating.  The capacitor impedance at high frequencies is primarily composed of the ESR and the ESR combined with the ripple current determines the power dissipation.
Aluminum and tantalum electrolytic capacitors are suitable at lower ripple currents however at high ripple currents, capacitors with a much higher ripple current rating, which is associated with a lower ESR, like polymer aluminum or tantalum capacitors are required.
Ceramic output capacitors are sometimes used but have special considerations because their ESR is so low that it impacts feedback loop stability.  The same would apply to a film capacitor.
The following users thanked this post: mikeinfodoc
Offline Siwastaja
« Reply #5 on: May 19, 2020, 04:56:02 pm »
You get the ripple current from
dI/dt = V/L
dt = ontime (or offtime)
V = voltage over inductor during the ontime (or offtime)
Then look at the ripple current rating of the capacitor.
You are pretty much done at that point, with electrolytic capacitors; if you get large enough part to handle the ripple current, it has quite some capacitance to deal with ripple voltage, as well.
Buck output is about an order of magnitude easier on the caps than the buck input. Electrolytics are often OK, even as-is.
Buck input requires lower ESR, and the input loop area should be small, easier done with small ceramics with less lead stray inductance.
Never use tantalum unless you know what you are doing.
« Last Edit: May 19, 2020, 04:57:47 pm by Siwastaja »
