Author Topic: Are there lithium battery management chips that replace lead-acid batteries?  (Read 1243 times)
Online daisizhouTopic starter
  • Country: cn
I have a Yamaha motorcycle,It uses 12v lead acid battery,Usually this kind of lead-acid battery has a service life of only 2-3 years.
I've seen a lot of people use lithium batteries instead, but it looks like they're amateur-made and not legitimate products.
The most common solution I see is the lithium iron phosphate battery solution,But they hardly use battery management chips, some even simply connect positive and negative。
I was wondering if there are any specialized chips suitable for lithium battery management used on motorcycles?
Because the starting current is usually 90A-120A,Conventional lithium batteries will disconnect the battery cells after they are fully charged, but they cannot be disconnected on motorcycles because lead-acid batteries have trickle charging. In other words, a lead-acid battery is similar to a "load resistor" after it is fully charged.
daisizhou#sina.com #=@
Offline thm_w
  • Non-expert
Most 12V Lifepo packs have a BMS inside. It would be very odd not to.
Here is one example: https://www.amazon.ca/MOSEWORTH-LiFePO4-MOS7B-4-Motorcycle-Kawasaki/dp/B093BZYWNK
You can also get lithium which also has BMS, as seen in the photos, not cheap but it is quality: https://no.co/products/lithium/powersport
No, the BMS will only disconnect the cells if it has been overcharged. Max recommended charge voltage is around 14.6V. The absolute max cell voltage is ~4.2V or 16.8V for the pack. So BMS might cut out somewhere around there. A good battery charger would not exceed that voltage, or you can get specific lithium 12V chargers.
Same for the motorcycles alternator, it should not exceed 15V unless something is wrong.
