Author Topic: High voltage issue of Raspberry Pi 4 PSU with EU mains connector  (Read 3812 times)
Offline Karel
Re: High voltage issue of Raspberry Pi 4 PSU with EU mains connector
« Reply #25 on: January 28, 2024, 07:47:02 am »
If this is a problem, simply add an external ground wire to your class II equipment.
There is no way to connect ground to this PSU. It don't allows disassemble without enclosure damage and there is no ground pin on its mains connector...
Connect ground/earth to the negative output (as I wrote before). No need to open the power supply.
Online radiolistenerTopic starter
  • Country: ua
« Reply #26 on: January 28, 2024, 03:02:32 pm »
It don't have negative output, only USB-C (on the cable which is soldered on the PSU side) which don't allows to connect ground in parallel with load.
Technically it can be done by cut off the cable and solder ground to the GND wire, but again it requires damage of the PSU integrity.
« Last Edit: January 28, 2024, 03:07:30 pm by radiolistener »
Offline Karel
« Reply #27 on: January 28, 2024, 03:08:54 pm »
It don't have negative output, only USB-C (on the cable which is soldered on PSU side) which don't allows to connect ground in parallel with load.
Cut the cable and reconnect te wires. That way you'll have access to the negative/GND wire.
