I have a Yamaha motorcycle,It uses 12v lead acid battery,Usually this kind of lead-acid battery has a service life of only 2-3 years.
I've seen a lot of people use lithium batteries instead, but it looks like they're amateur-made and not legitimate products.
The most common solution I see is the lithium iron phosphate battery solution,But they hardly use battery management chips, some even simply connect positive and negative。
I was wondering if there are any specialized chips suitable for lithium battery management used on motorcycles?
Because the starting current is usually 90A-120A,Conventional lithium batteries will disconnect the battery cells after they are fully charged, but they cannot be disconnected on motorcycles because lead-acid batteries have trickle charging. In other words, a lead-acid battery is similar to a "load resistor" after it is fully charged.
