Redefine the goal. It's quite wasteful to cool a whole house when the actual objective is to keep the people cool.
Yeah, heard this before and don't agree.
I don't want to be in one room and walk to another and freeze or melt my round ones off. when we are all home and in different areas, the whole house pretty much does need to be heated or cooled.
The idea of AC that activated when you are in that room might be OK if you live in a matchbox but I don't and don't want to. Didn't work my arse off to have what I do and make all the sacrifices over the years to live uncomfortably as I once did. The areas in my home are large and the AC is going to take a good 10 Min to have any effect on a hot or cold day.
(Are you the kind who turns on every light in the house just because you're working in one room?)
While my attitude may not fit the green agenda, there are few people I have come across that actually do more to fit the green, sustainable mindset than I do. I Couldn't give a rats about the PC green washed religion, I do it to save money and because I like to be as independent as possible.
I have all LED lighting in my home I changed over when we got here from the all incandescent. I figured out I can light the entire joint up like daylight now for WELL under 150w. Every light in the house, the front yard landscape lighting and the back yard ( runway) floodlights as my wife calls them. When the lights are 4-6W instead of 50-150, the watts go a long way. Even if I did have every light on all the time, my smallest solar array would make that power back up in under 1 hour and provide well over a weeks worth of 24/7 lighting in a day. It's one of 4 arrays.
My 20+Kw solar setups make more power than I can use 9 months of the year and this year I'll fix that 3 month winter deficit. I have all this solar and generator power so I can heat and cool my whole house and have every other power sucking amenity I wish with very low grid consumption. According to my power bill, I am still at about half the power consumption an average SINGLE person home uses which gives us a real world efficiency of 6x the average.
How does your power consumption rate?
Those that want to play the green guilt game with me will get their noses rubbed in it every single time.
That's where the directed cooling controller comes into play - detect where the people are in the room using modern technology like infrared sensors and computer vision, then use servos to direct the airflow towards them.
In MY real world scenario, I believe this would be a detriment.
I'm working in my office. AC detects I'm here and all the cooling is fed here. I walk to the bathroom and it tracks me and sends the air there. I'm there for a minute or 30
and then come out and go to the kitchen to make a Cuppa and something to eat. Ac is directed there. Being this would be a new system , it's no doubt going to be inverter so sensing the room I'm in is 35oC, the thing goes full tilt into cooling that room down. In the mean time I'm in there sweating like a pig and uncomfortable.
As it gets to a decent temp, I'm done and walk back to the office which has been warming up because no one is in it so again the thing winds up pouring all the cold it can in there to get the temp back to the set level whatever that may be. Repeat cycle 5-10 times a day.
Of course if I go out the house to do something it shuts down ( I take it) and place warms up again.
The Wife and Daughter come home, fill most of the remaining rooms of the place and now because the solar on the roof is producing 3 Kw instead of 20 it was earlier in the day, the thing is again flat out only now pulling from the grid in peak times.
Don't give a rats about that either but it is against the green correct agenda they preach and I don't see it gets me any benefit.
MY way of doing it is to have the whole house cooled from about mid day when it tends to get over 30 inside off my solar which would other wise go to waste. I can run the AC flat out and STILL backfeed so why not. I disagree with your position of only people being needed to be cooled or heated. it's easy to drop the temp of the air but then the objects in a home just act like big thermal mass radiators and I have spent a lot of time learning about thermal mass. Unless the furniture, walls and everything in the home is also cooled, it's just going to keep radiating heat when the air is cooler and heat it up.
Basic law of thermodynamics, heat always seeks cold.
By never allowing the interiour of the house to get hot, the AC is just maintain temp, not trying to bring a hot house down to where it should be.
Just like an aeroplane, more economical to Cruise and maintain speed in the high thin air than it is to push through the thick air lower down.
For example, if you need to buck the voltage by 20V, you only need a 420VA transformer. The transformer would be connected so that the primary is across the mains as usual but the secondary is connected in series between the input and output to drop the voltage.
http://www.repairfaq.org/sam/pwrfaq.htm#ipsulv
I'm not sure I fully understand how that works and I am even more unsure it would work with a GTI but I shall study the concept and that link page more thoroughly. It may not be something I want to do in this application but there looks to be much useful information there that may be applicable to my many other projects and hair brained ideas.
Thank you for what looks like a very interesting and useful link which I have bookmarked.
