If the output is coming directly from a low impedance amplifier, the RL is necessary to provide some matched resistance for the parallel capacitor to act against. Otherwise it's just shorting out the amplifier, and the amplifier will win*.
*For small signals. For large signals, it will go into current limiting, which manifests as slew rate limiting. And, assuming it doesn't oscillate, which is a stability issue in poorly made designs.
