Solder it to a 14 pin DIL header, preferably *NOT* turned pin as they are a lot more fragile than a stamped pin. As long as your ZIF socket pins are <0.6mm for the thinner dimension, and the two rows are reasonably close to 0.3" apart, Aries 14-600-10 (tin) or 14-600-11 (gold) would do the job, extending the pins by approx 7.5 mm.
