Author Topic: You Got A mail!!!  (Read 13801 times)
Offline ChrisGreece52Topic starter
  • Electronics Engineer - Hacker - Nerd
Re: You Got A mail!!!
« Reply #25 on: May 17, 2013, 09:51:48 am »
http://www.ebay.com/itm/24-Tune-Wireless-Digital-Doorbell-Door-Bell-Chime-Alarm-/390579834465?pt=AU_Home_Personal_Security&hash=item5af05f4e61
That Actually seems nice i could tweak the switch to fit and work with the mailbox... but i dont know its range ... ill ask the seller
Also the batteries are simple to find.
Offline GK
« Reply #26 on: May 17, 2013, 10:21:20 am »
How about just sticking a wireless door bell button to the front of the letter box with a little plaque "Attention postperson*: Press to notify of mail delivery".
* I'm being politically correct now.
Bzzzzt. No longer care, over this forum shit.........ZZzzzzzzzzzzzzzzz
« Reply #27 on: May 17, 2013, 10:26:11 am »
Too much hacking videos sorry
Seems pretty good but kids walk a lot in from of the staircase and the mailbox is a few steps higher from the ground so i think that the little bastards will keep pressing the doorbell (at least that is what i would do if i was 5 years younger)
« Reply #28 on: May 19, 2013, 03:43:10 pm »
I contacted the seller and he said that the range of the doorbell is 100 meters that is more than enough for me but there is a problem... i can not find the proper sensor to replace the push button one that the device will already have.
I tried to search for a hall effect one but they are pretty expensive (8 dollars a piece) but the A1302 one seems nice and its pretty cheap too (1.40 from taydaelectronics.com)
http://www.taydaelectronics.com/a1302-continuous-time-ratiometric-linear-hall-effect-sensor-ic.html
Check the schematic a bit and make some suggestions because i dont know how to use it as a switch.
Anyway thank you and please help because the sensor is the trickiest part.
Online SeanB
« Reply #29 on: May 19, 2013, 04:12:56 pm »
One cheap alarm door contact. A reed switch in a nice case, and a matching magnet. Cheap or free, depending if you can get on a building site and look through the scrap and grab one from a renovation, or find them at your local hardware or used building material supplier, or any alarm installer has old ones.
« Reply #30 on: May 19, 2013, 05:33:30 pm »
sorry but this would not do it i need to track if the lead is open or closes or if there is something inside.
A reed switch will be a bit tricky to be activated by lightweight folders
« Reply #31 on: May 19, 2013, 05:39:15 pm »
Well that was my fault .... you meant something like that
http://www.taydaelectronics.com/fr2s1020-reed-switch-1-5a-10-20-a-t-spst-no-200-vdc-vac-fr2s1020-0520.html
I understood something like this
