Author Topic: not work  (Read 17955 times)
Offline madires
  • A qualified hobbyist ;)
Re: not work
« Reply #50 on: May 29, 2014, 04:23:41 pm »
i can not finde :(
http://www.mikrocontroller.net/svnbrowser/transistortester/ as linked in the download section of the project's web page.
Online PA0PBZ
Re: not work
« Reply #51 on: May 29, 2014, 05:25:19 pm »
I think this is what you need, but you can only be sure by trying.  :-//
Offline AigarsTopic starter
  • Country: is
  • elerepair
Re: not work
« Reply #52 on: May 29, 2014, 09:05:03 pm »
tx. i tray make this.
Offline M4trix
  • Country: hr
Re: not work
« Reply #53 on: May 29, 2014, 09:14:18 pm »
That won't make any difference if he doesn't have the right programming equipment for the microcontroller.
  • Country: is
  • elerepair
Re: not work
« Reply #54 on: May 29, 2014, 09:15:13 pm »
i can not finde :(
but this its tester wif screen dimmer.
  • Country: is
  • elerepair
Re: not work
« Reply #55 on: May 29, 2014, 09:25:13 pm »
nop. dont work
Online PA0PBZ
Re: not work
« Reply #56 on: May 29, 2014, 09:27:40 pm »
I give up!
Offline dannyf
Re: not work
« Reply #57 on: May 29, 2014, 09:30:57 pm »
You guys are super nice people.
Offline madires
Re: not work
« Reply #58 on: May 29, 2014, 09:59:08 pm »
If you don't like the PWM dimmer just leave it out. Anyway, you're using the old circuit which is obsoleted by Karl-Heinz' improved circuit (see the link for the documentation some posts earlier).
  • Country: is
  • elerepair
Re: not work
« Reply #59 on: May 29, 2014, 10:38:12 pm »
NO NO, ITS OK. I CAN MAKE A PLATE AND BUILD THIS. I ONE TIME BUILD THIS, BUT EFTIR TAKE A PART. I HAVE SAMWHERE PLANE.
TX A LOT
