I've been playing around with a case design for the 18x6 ones. it needs some tweaking and to actually be printed (and my 3D printer is awaiting a new hotend to arrive). I can't print right now but here's what I've designed for a case.
100mmx60mmx25.4mm (just a starting point, like i said needs tweaking)
(edit, actually a bit bigger, the square part of of it is 100x600)
designed to be stackable (magnets on bottom, countersink screws on tops)
setup for 4W on back (.75in spacing)
2 piece print
One tweak is I embossed the top by 1mm, kinda messes up the stacking after I looked at it
fixed this by adding a 1mm recessed area then embossing by 1mm (see capture4)
Comments welcome, changes, tweaks all welcome.
happy to post STL to thingverse when done (or just here if preferred)
note:
i had a 10 decade thumbwheel and that's the dimensions I used. it could be smaller for a 6 decade unit
