Author Topic: BTS5016 High Side Dual Switch  (Read 505 times)
Offline Quarlo KlobrigneyTopic starter
  • Country: pt
  • This Space For Rent
« on: June 17, 2021, 03:21:45 pm »
I am lost as to the lack of a proper "truth table" for the device.
My question is, should the DEN pin be high or low for output?
In Table 8 on page 28, it shows me that it should be high for the load to be provided supply voltage - current.
Is this correct? I know it's and old Infineon part that they touted and dropped for the latest thing, but it's a question of having it in quantity already.
Has anyone used this family of MOSFET switches before?
https://www.infineon.com/dgdl/Infineon-BTS5016-2EKA-DS-v01_00-EN.pdf
Voltage does not flow, nor does voltage go.
Offline mikerj
Re: BTS5016 High Side Dual Switch
« Reply #1 on: June 17, 2021, 07:43:45 pm »
Neither! The DEN and DSEL pins are for diagnostic purposes, not for controlling the output.  The truth table for the diagnostic pins is in section 7 of the datasheet.
The IN0 and IN1 pins control the output, and are active high as per the diagrams in section 5.
  • Country: pt
« Reply #2 on: June 26, 2021, 11:41:34 pm »
I've been awfully busy to respond. I also haven't tested the IC yet, but I appreciate your feedback. Perhaps next weekend will be better to give it a go.
« Last Edit: June 29, 2021, 03:46:42 am by Quarlo Klobrigney »
