@AndrewBCN I have few questions. I have made some changes to code, some things were really confusing for me in the beggining so I decided to change some names to something more meaningful.
Changes that are done, are made on
fit-gpsdo branch on my fork. (this is WIP - Work In Progress branch so it can be messy
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
https://github.com/felixd/STM32-GPSDO/tree/fit-gpsdoIdea is:
GPSDO_FUNCTION_IDENTHow it looks right now on my side:
#define GPSDO_DISPLAY_OLED // SSD1306 128x64 I2C OLED display
//#define GPSDO_VCTL_MCP4725 // MCP4725 I2C 12-bit DAC
#define GPSDO_VCTL_PWM // STM32 16-bit PWM DAC, requires two rc filters (2xr=20k, 2xc=10uF)
//#define GPSDO_SENSOR_AHT10 // I2C temperature and humidity sensor
#define GPSDO_GEN_2kHz // Generate 2kHz square wave test signal on pin PB9 using Timer 4
//#define GPSDO_SENSOR_BMP280 // SPI atmospheric pressure, temperature and altitude sensor
//#define GPSDO_SENSOR_INA219 // INA219 I2C current and voltage sensor
// TODO: When UART2 (Bluetooth) is activated less messages are shown on OLED and UART1 (USB serial)
#define GPSDO_UART2 // UART2 (Bluetooth) serial (HC-06 module)
#define GPSDO_ADC_5V // Vcc (nominal 5V) ; reading Vcc requires 1:2 voltage divider to PA0
#define GPSDO_ADC_3V3 // Vdd or Vref (nominal 3.3V) reads AVREF internal ADC channel
// TODO: Below Calibration definition is not used..
#define GPSDO_CALIBRATION // Auto-calibration is enabled
#define GPSDO_GPS_UBX_CONFIG
//#define GPSDO_GPS_VERBOSE_NMEA // GPS module NMEA stream echoed to USB serial xor Bluetooth serial
Vcc and Vdd were super confusing for me in the beggining (same on Schematics). It was not clear what Voltages I should expect so I've changed names to point what voltages we are working with. Same with variable names
GPSDO_CALIBRATION is not used at all. From my point of view it should work as it is working right now: Calibration is done everytime after restart. This option sould be removed from code.
GPSDO_GPS_VERBOSE_NMEA I have just dirrectly connected to Serial1 on breadboard to see all GPS<->STM32 traffic. That's much better in my opinion. You have proper NMEA messages which can be decoded by
u-Center app. An for that, this port should be available as well on PCB
I have also formated code (autoformating in Arduino IDE v1 with
indent-preproc-block option ON)
Example of what I am writting about:
#ifdef GPSDO_SENSOR_INA219
#include <LapINA219.h> // LapINA219 library library
LapINA219 ina219(0x40); // create object INA219 with I2C address 0x40
float ina219volt = 0.0, ina219curr = 0.0;
TwoWire Wire3(PB4, PA8); // Second TwoWire instance for INA219 on SDA3/SCL3 (should be put somewhere more fitting but must stay global)
#endif // INA219
Once functions / block are recognized and corrected in
GPSDO.ino they should be move outside. Example
GPS should be moved to
gps.h /
gps.c file. Same with
sensors--
UART output format: I suggest to format data in Arduino IDE Serial Plotter format.
https://docs.arduino.cc/software/ide-v2/tutorials/ide-v2-serial-plotterYou can directly save that to CSV file and process data later on. You can as well parse data with an external application.
That's where I am slowly going to. Waiting for Your feedback.
BTW: My Racal-Dana 9514 (last calibrated 11/10/2012) was only 0.4 Hz off (it's running for more than 30 hours already). I have just adjusted it, which was a bit tricky but I have managed to do it
https://www.eevblog.com/forum/testgear/list-your-test-equipment-score-here!/msg790750/#msg790750Cheers, Paweł.
