Author Topic: Yet another DIY GPSDO - yes, another one  (Read 173763 times)
0 Members and 13 Guests are viewing this topic.
Offline iannez
Re: Yet another DIY GPSDO - yes, another one
« Reply #400 on: January 24, 2022, 10:04:25 pm »
Hi all.
I have given up on the project.  I have a box of parts and don't know how to proceed.
for Bob91343
First you need to install the IDE of Arduino is to configure it
As wisely Andrewbnc wrote to you.
have you managed at least until here?
A.
Offline Renate
« Reply #401 on: January 24, 2022, 10:47:16 pm »
Here you go, use this. See if there are any big jumps in your printout. You can print as you have, but add this.
/* This is ugly coding, but we need something simple to see what's going on */
void print_hexit(uint8_t x)
   x&=0xf;
   if (x>=10) x+='a'-10;
   else x+='0';
   print_however_char(x); // I don't know how you print a char
void print_x64(uint64_t x)
   print_hexit((uint8_t) (x>>60));
   print_hexit((uint8_t) (x>>56));
   print_hexit((uint8_t) (x>>52));
   print_hexit((uint8_t) (x>>48));
   print_hexit((uint8_t) (x>>44));
   print_hexit((uint8_t) (x>>40));
   print_hexit((uint8_t) (x>>36));
   print_hexit((uint8_t) (x>>32));
   print_hexit((uint8_t) (x>>28));
   print_hexit((uint8_t) (x>>24));
   print_hexit((uint8_t) (x>>20));
   print_hexit((uint8_t) (x>>16));
   print_hexit((uint8_t) (x>>12));
   print_hexit((uint8_t) (x>>8));
   print_hexit((uint8_t) (x>>4));
   print_hexit((uint8_t) x);
Offline bob91343
« Reply #402 on: January 25, 2022, 12:53:54 am »
Frankly, it has been so long since I looked at it, I don't remember how far I got.  I need to look in the box, but I don't recall installing any firmware.
Offline felixd
    • FlameIT - Liquid Immersion Cooling
« Reply #403 on: January 25, 2022, 09:00:41 am »
[NOTE]
That might be interesting.
http://triode.dip.jp/honkytonk/2021/06/electronicworks/an-introduction-of-my-original-gpsdo-a-frequency-standard-oscillator-with-stm32.html
Microcontroller: STM32F411CEU6
GPS module: Icofochina ATGM332D 5N31
OCXO: Morion MV89A
EFC control DAC: PCM5102A <-- That's interesting. 32bit DAC
Pawel 'felixd' Wojciechowski
FlameIT - Liquid Immersion Cooling https://flameit.io
OpenPGP: 0x9CC77B3A8866A558 https://openpgp.flameit.io/
The following users thanked this post: 1001
Offline iannez
« Reply #404 on: January 25, 2022, 11:03:57 am »
Goodmorning everyone,
The problem relating to frequency jumps seems related to the function:
if (gpsWaitFix(waitFixTime))
which is called into the main loop.
It seems that sometimes the system reveals a loss of fix and therefore passes in the else where in practice it loses about a second and then reset the buffers at the next round setting the variable:
flush_ring_buffers_flag = true;
which is then evaluated in the ISR_2Hz
By putting a:
  return;
Immediately after else condition in the function the problem seems to resolve.
    startGetFixmS = millis();    // have a fix, next thing that happens is checking for a fix, so restart timer
  else // no GPS fix could be acquired for the last five seconds
   return;  // <======= ADD THIS LINE
    yellow_led_state = 1;        // turn on yellow LED
Probably it should be understood because it detects a nofix when it is not true.
AndrewBNC's work on buffers and related mathematics is perfect :)
Obviously every advice is welcome, AndrewBNC's project is very interesting.
@Renate
thanks for the code, I try it as soon as I can
by, A.
The following users thanked this post: felixd
Offline Renate
« Reply #405 on: January 25, 2022, 11:43:07 am »
Oops, I see what confused me there. Your print is probably ok.
The first example ran out of steam right before one billion.
You are also printing out the buffer stats in a fixed order, not by age.
That means there is a break in the middle of your listing between the newest and the oldest.
That is: 4, 5, 6, 7, 8, 9, 10, 1, 2, 3
Offline iannez
« Reply #406 on: January 25, 2022, 12:57:48 pm »
Hi Renate,
I made the change this morning as reported in the previous post.
Everything looks fine now.
Obviously the problem of the Satfix control logic must be solved, if that is the prob.
Here to follow the statistics in the second 6602 of runtime, I await the 10000s for the statistic and then restart with some modifications.
measurements using 64-bit counter:
64-bit Counter: 65996867149
Frequency: 10000008 Hz
10s  Avg: 10000008.2 Hz
100s  Avg: 10000008.17 Hz
1,000s  Avg: 10000007.678 Hz
10,000s  Avg: 0.0000 Hz
avgupsec: 6602
 circbuf_ten64[0]:  65986867141
 circbuf_ten64[1]:  65996867149
 circbuf_ten64[2]:  66006867157
 circbuf_ten64[3]:  65906867075
 circbuf_ten64[4]:  65916867084
 circbuf_ten64[5]:  65926867092
 circbuf_ten64[6]:  65936867100
 circbuf_ten64[7]:  65946867108
 circbuf_ten64[8]:  65956867116
 circbuf_ten64[9]:  65966867125
 circbuf_ten64[10]: 65976867133
 circbuf_ten64[11]: 60156862557
The 11 entry circular buffer as above is populated starting from 0 and reaching [10].
The entry [11] I have not yet understood where it is overwritten,
I will debug at the next restart on value change to show me when and where it happened.
The next round will be:
3, 4, 5, 6, 7, 8, 9, 10, 1, 2 and 2, 3, 4, 5, 6, 7, 8, 9, 10, 1 and so on ...
bye, A.
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #407 on: January 25, 2022, 03:32:13 pm »
Your code is broken. There are 11 elements in your buffer, indexed 0 to 10. At least your debug code accesses elements 0 to 11. That is certainly not correct. Check if you have other places in the program with the same bug.
Offline AndrewBCNTopic starter
« Reply #408 on: January 25, 2022, 06:13:56 pm »
By putting a:
  return;
@Renate
by, A.
Excellent work finding this bug! I am going to try your solution ASAP. But it makes sense, when I have very good satellite reception I don't get the "jumps" so much.
Thank you!
Offline bob91343
« Reply #409 on: January 25, 2022, 06:14:32 pm »
Perhaps someone wants to volunteer to finish my unit.  I would pay for postage at least if someone can get this thing working.
Offline iannez
« Reply #410 on: January 25, 2022, 06:49:02 pm »
Hi Thinkfat,
The problem is simply that cycle on the total length of the array,
But it's not a problem because the arrays are correctly filled.
volatile uint64_t _s_circbuf_ten64 = 0;
 _s_circbuf_ten64 = sizeof(circbuf_ten64) / sizeof(uint64_t);  _s => size circbuf_ten64  => 11!!!!
for(int i=0; i <= _s_circbuf_ten64; i++) //   => probably  (_s_circbuf_ten64-1) make sense
  print lines like  circbuf_ten64[i]:
Following an example on 10s buffer:
circbuf_ten64[0]:  28485109  <= NEW ENTRY same value as 64-bit Counter   <= FIRST VALUE in array0 correct
 circbuf_ten64[1]:
 circbuf_ten64[2]:
 circbuf_ten64[3]:
 circbuf_ten64[4]:
 circbuf_ten64[5]:
 circbuf_ten64[6]:
 circbuf_ten64[7]:
 circbuf_ten64[8]:
 circbuf_ten64[9]:
 circbuf_ten64[10]:
 circbuf_ten64[11]:
Fix time 958mS
64-bit Counter: 28485109
Frequency: 10000003 Hz
10s  Avg: 0.0 Hz
100s  Avg: 0.00 Hz
1,000s  Avg: 0.000 Hz
avgupsec: 4
 circbuf_ten64[1]:  38485113  <= NEW ENTRY same value as 64-bit Counter
 circbuf_ten64[2]:
 circbuf_ten64[3]:
 circbuf_ten64[4]:
 circbuf_ten64[5]:
 circbuf_ten64[6]:
 circbuf_ten64[7]:
 circbuf_ten64[8]:
 circbuf_ten64[9]:
 circbuf_ten64[10]:
 circbuf_ten64[11]: 28485109  <= first value now shifting in last position and remaing here...
Fix time 966mS
64-bit Counter: 38485113
Frequency: 10000004 Hz
10s  Avg: 0.0 Hz
100s  Avg: 0.00 Hz
avgupsec: 5
 circbuf_ten64[2]:  48485116  <= NEW ENTRY same value as 64-bit Counter
 circbuf_ten64[3]:
 circbuf_ten64[4]:
 circbuf_ten64[5]:
 circbuf_ten64[6]:
 circbuf_ten64[7]:
 circbuf_ten64[8]:
 circbuf_ten64[9]:
 circbuf_ten64[10]:
Fix time 963mS
64-bit Counter: 48485116
10s  Avg: 0.0 Hz
100s  Avg: 0.00 Hz
avgupsec: 6
and so on ... in the end show this:
 circbuf_ten64[3]:  58485119
 circbuf_ten64[4]:  68485122
 circbuf_ten64[5]:  78485126
 circbuf_ten64[6]:  88485129
 circbuf_ten64[7]:  98485132
 circbuf_ten64[8]:  108485135
 circbuf_ten64[9]:  118485139  <= NEW ENTRY same value as 64-bit Counter
 circbuf_ten64[10]:
Fix time 959mS
64-bit Counter: 118485139
10s  Avg: 0.0 Hz
100s  Avg: 0.00 Hz
avgupsec: 13
 circbuf_ten64[10]: 128485142  <= NEW ENTRY same value as 64-bit Counter
Fix time 961mS
64-bit Counter: 128485142
10s  Avg: 10000003.3 Hz
100s  Avg: 0.00 Hz
avgupsec: 14
 circbuf_ten64[0]:  138485145  <= NEW ENTRY same value as 64-bit Counter    <= new beginning of cycle but last value is the same
 circbuf_ten64[11]: 28485109       <= SAME VALUE for many many cycle, when and where change?
Fix time 956mS
64-bit Counter: 138485145
10s  Avg: 10000003.2 Hz
100s  Avg: 0.00 Hz
avgupsec: 15
 circbuf_ten64[1]:  148485148  <= NEW ENTRY same value as 64-bit Counter
Fix time 962mS
64-bit Counter: 148485148
100s  Avg: 0.00 Hz
avgupsec: 16
and so on...
Excellent work finding this bug! I am Going to Try your solution ASAP. But it Makes Sense, When I Have Very Good Satellite Reception I Don't Get The "Jumps" So Much.
Thank You!
I am Happy That I Can Help !!!
This project is very nice and not expensive, this makes  it quite easily.
bye A.
Offline thinkfat
« Reply #411 on: January 25, 2022, 06:58:43 pm »
Your "not a problem" is a classic "out-of-bounds" access. C is not a managed language. Accessing the array at index 11 means you're accessing, possibly writing to a memory location that is occupied by another variable. No wonder you get strange values.
Offline iannez
« Reply #412 on: January 25, 2022, 07:44:17 pm »
 thinkFat  you are perfectly right,
 thanks for the clarification :)
bye, A.
« Reply #413 on: January 25, 2022, 09:56:13 pm »
Yes, that's an out-of-bounds memory access.
Offline felixd
« Reply #414 on: January 25, 2022, 10:09:08 pm »
@bob91343
Do You have already Arduino IDE? If not, install it from here:
https://www.arduino.cc/en/software (Arduino IDE 1.8.19)
then You have to install STM32Duino support in Arduino IDE. Here You can read how to do that:
https://github.com/stm32duino/wiki/wiki/Getting-Started
PM me when You finish this step. Do You use Discord? This is offical EEVBlog channel there: https://discord.gg/qGMhKbq (try it, it's IRC like software)
[EDIT]
After it's done You can watch this video. It explains how to connect to board (program, access serial data etc)
« Last Edit: January 25, 2022, 11:24:49 pm by felixd »
The following users thanked this post: AndrewBCN
Offline Badwater
« Reply #415 on: January 26, 2022, 11:48:47 am »
Got it working  :-+
... but commands are not recognized
Any ideas why?
I am more a HW guy ...
12:44:25.193 -> Voltages:
12:44:25.193 -> Vctl: 1.06  DAC: 2397
12:44:25.193 -> VctlPWM: 2.12  PWM: 45074
12:44:25.193 -> Vcc: 4.71
12:44:25.193 -> Vdd: 3.31
12:44:25.193 ->
12:44:25.193 -> Frequency measurements using 64-bit counter:
12:44:25.193 -> 64-bit Counter: 13442871830
12:44:25.193 -> Frequency: 10000000 Hz
12:44:25.193 -> 10s Frequency Avg: 10000000.0 Hz
12:44:25.193 -> 100s Frequency Avg: 10000000.07 Hz
12:44:25.193 -> 1,000s Frequency Avg: 10000000.063 Hz
12:44:25.193 -> 10,000s Frequency Avg: 0.0000 Hz
12:44:25.193 ->
12:44:25.239 -> Unrecognized command [V]
12:44:25.239 ->
« Reply #416 on: January 26, 2022, 07:27:17 pm »
Got it working  :-+
Any ideas why?
12:44:25.193 ->
12:44:25.193 ->
12:44:25.239 ->
Well done!  :-+
And many thanks for the picture.
As to why the commands are not recognized... I have no idea.  :-//
It could possibly be due to a change in the command library API. Commands work fine here.
The following users thanked this post: Badwater
Offline felixd
« Reply #417 on: January 26, 2022, 07:30:59 pm »
I have a plan to run it tonight (8PM right now).
Software is already uploaded, I have managed to program Black Pill. Altough it doesn't look like original one, (it doesn't have USB-C). I found that yesterday. Pinout looks different as well.
Going back to wiring and locating correct pins... DOH...
Offline Badwater
« Reply #418 on: January 26, 2022, 09:03:57 pm »
... recognizing commands .....
-> reading the comments in the code helps a lot (well done :clap:)
//  "\n" means only newline needed to accept command
... works fine  :-+
Tnx, Frank
Offline felixd
« Reply #419 on: January 26, 2022, 10:26:29 pm »
[UPDATE on Bob91343]
Quick update on @Bob91343 situaton. After exchanging tons of screenshots on Facebook and some remote desktop VooDoo I have managed to help Bob with Arduino and BlackPill board.
So Bob already has:
- Latest Arduino installed
- All required libs for compilling
- STM32 (STM32CubeProgrammer) installed. Just for DFU checking.
- We were able to upload code to uC.
- After uploading code we were able to connecto Serial Monitor
We have received simillar messages like one below.
23:37:38.313 -> UBX command sent, waiting for UBX ACK...
23:37:38.313 ->  * Reading ACK response:  (FAILED!)
23:37:41.297 -> Oops, something went wrong here...
23:37:41.297 -> B562624240FFFF23000010270050FA0FA06402C100001027000000004953
I assumet it's becuase program cannot connet Yet with u-Blox. I am fighting with that at the moment on my side.
- Bob knows how to set BlackPill in BOOT mode.
Now Bob need some assitance with wiring things and setting up code to work with components he has. I can't assist him now with that, as I need to go though that for myself ;)
Good luck Bob!
« Last Edit: January 26, 2022, 10:39:19 pm by felixd »
The following users thanked this post: bingo600, Badwater, bob91343, Renate, AndrewBCN
Offline bob91343
« Reply #420 on: January 26, 2022, 11:00:39 pm »
Yes felixd you worked some magical miracles with my board.  Now I need to think about what comes next.  I have the diagram so will wire up the units and see what to do.
I should pick up some perf board and put it on that.
Big thanks to you felixd!  I could never have done that.  It's what happens when your engineering becomes obsolete.
« Reply #421 on: January 27, 2022, 01:22:45 am »
Yes, that means the STM32 Black Pill did not get the expected response from the u-blox GPS module.
You can check:
1. That you have a u-blox M8N module. I am not sure that command works with the M6N or M7N.
2. That the serial connection to the u-blox module is working. (you have examples in the GPS library that do that).
3. That your GPS module is working. You can connect it to a PC using a USB to serial adapter.
Offline felixd
« Reply #422 on: January 27, 2022, 01:44:21 am »
uC was powered up before GPS ;) All fixed.
02:30:36.264 -> $GPGSA,A,3,19,01,21,22,32,17,03,31,,,,,2.29,1.39,1.81*04
02:30:36.264 -> $GPG92,35*7A
02:30:36.264 -> $GPGSV,3,3,10,31,18,103,28,32,33,053,30*7F
02:30:36.264 -> $GPGLL,5231.xxxxx,N,01736.xxxxxx,E,013037.00,A,A*69
02:30:37.156 -> $GPRMC,013038.00,A,5231.xxxxxx,N,01736.xxxxxxx,E,0.041,,270122,,,A*79
02:30:37.156 -> $GPGGA,013038.00,5231.xxxxx,N,01736.xxxxxx,E,1,08,1.39,129.5,M,37.4,M,,*58
02:30:37.203 ->
02:30:37.203 -> Fix time 939mS
02:30:37.203 -> Uptime: 000d 00:04:00
02:30:37.203 -> New GPS Fix:
02:30:37.203 -> Lat: 52.xxxxxx Lon: 17.xxxxxx Alt: 129.5m
02:30:37.203 -> Sats: 8 HDOP: 1.39
02:30:37.203 -> UTC Time: 01:30:38 Date: 27/1/2022
02:30:37.203 ->
02:30:37.203 -> Voltages:
02:30:37.203 -> Vctl: 0.33  DAC: 2400
02:30:37.203 -> VctlPWM: 0.54  PWM: 0
02:30:37.203 -> Vcc: 1.34
02:30:37.203 -> Vdd: 3.31
02:30:37.203 ->
02:30:37.203 -> Frequency measurements using 64-bit counter:
02:30:37.203 -> 64-bit Counter: 2315230278
02:30:37.203 -> Frequency: 9999990 Hz
02:30:37.203 -> 10s Frequency Avg: 9999990.1 Hz
02:30:37.203 -> 100s Frequency Avg: 9999990.18 Hz
02:30:37.203 -> 1,000s Frequency Avg: 0.000 Hz
02:30:37.203 -> 10,000s Frequency Avg: 0.0000 Hz
02:30:37.203 ->
02:30:37.249 ->
Tomorrow I will play a bit with Vctl/PWM (there is small issues in code) + I haven't connected Vctl at all :D
Great job Andrew! (+ kind reminder about pull request). I suggest also for others, whenever we are talking about code it would be great to point it on GitHub so we all know what we are talking about and which version we are talking about ;)
Good night.
[UPDATE] We have working 10000000.00 Hz :) Since hardware is working fine I will now have time to look at software ;)
Fix time 949mS
Uptime: 000d 01:45:42
New GPS Fix:
Sats: 11 HDOP: 0.96
UTC Time: 17:41:29 Date: 27/1/2022
Voltages:
Vctl: 0.31  DAC: 2395
VctlPWM: 1.91  PWM: 37996
Vcc: 5.01
Vdd: 3.31
64-bit Counter: 63349355009
100s Frequency Avg: 10000000.00 Hz
1,000s Frequency Avg: 9999999.999 Hz
« Last Edit: January 27, 2022, 05:59:25 pm by felixd »
The following users thanked this post: Badwater, AndrewBCN
Offline iannez
« Reply #423 on: January 27, 2022, 04:57:05 pm »
Good work felixd !!!
Offline bob91343
« Reply #424 on: January 27, 2022, 06:02:10 pm »
felixd you are the man!  Single handed you pulled me up from disaster and now I have some hope that this project can be completed successfully.
Thank you once again.
Now I need to mull over the next step, probably assemble all the pieces.
