Mick, great job looks good and it works!!
I searching for some support:Please see the pic below. It seams as it would working well but I have some doubts.
1. The Frequency is the base /default freq. and without the =.xx value.
2. The PWM value is stable at 32400 (I set this value as it was the number that brings my prototype to 10MHz).
3. See the in..it before the voltage measurement
I transferred the elements from the breadboard (see earlier posted pic) to the development board (final version). Just the 74HC driver was added an the 100nF caps and a proper power supply.
I check over 2 days all parts several times ... measured the signals out (1pps/10MHz sinus and 10Mhz rec), Vctl=1,67V and sats=12 and GPS signal is fixed and green led on GPS blinking.
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
Also SW 0.5j and 0.6c tested.
Always the same ... the program loop on 'Please wait Calibrating...'. The only way is to skip calibrating in the program and than it works like on the picture. I guess without GPS disciplined..
Any hint/idea/tip? Everything is welcomeThank you in advance
