Author Topic: Crystal raised from PCB. Is that normal?  (Read 1350 times)
Offline TinkeringTomasTopic starter
« on: November 13, 2021, 10:02:26 pm »
Hey everyone!
After opening up a cheap VGA to HDMI adapter, I noticed the 24.567MHz crystal was raised from the PCB. I've never seen this before, and doubt it's a great idea...
Do you peeps know if this is done for a particular reason or did they just go "nah, it's good enough for Aus....AliExpress"?
Offline wraper
  • Country: lv
Re: Crystal raised from PCB. Is that normal?
« Reply #1 on: November 13, 2021, 10:05:21 pm »
The strange part is that its terminals are flat. Looks like SMD crystal with plastic part removed and terminals straightened. Probably they don't even fit into the holes and thus don't even go thru them.
Online ataradov
    • Personal site
« Reply #2 on: November 13, 2021, 10:21:12 pm »
Yep, they did not have though hole version, so they improvised. Now, flat pins provide more rigidity compared to round ones (at least in one direction).
At the same time, in my experience when you do this, metal weakens that you can realistically only un-bend them one time, after that they just break.
If you are bothered by it, find a crystal with the same frequency and replace it.
And it is strange that they even bothered to remove the plastic part. It is possible that they got the crystals from production line before the plastic was applied. Possibly even scraps that did not pass the test. Look under the package where the pins are attached. Are there any signs of bending?
« Last Edit: November 13, 2021, 10:23:14 pm by ataradov »
Alex
« Reply #3 on: November 13, 2021, 11:15:30 pm »
Good points! I too noticed that the pins weren't flat, but I somehow assumed there were just flat-pinned versions for some reason.
I've pulled out the little microscope and looked under the crystal. I haven't looked at the bottom of SMD crystals much and certainly not up their skirt (is this going to flag something now?  :-X) but it looks like a normal through-hole package to me. If you look closely, it appears the pins come out of the package round but are shoved into a tube that's flattened?
Would these type of pin lengths affect the signal much, you think? The output of the device is somewhat unstable and blurry (not usable for any length of time). It might have to do with the converter chip (just a single IC doing all the work) not syncing to the source properly, or just crappy components in general.
« Last Edit: November 13, 2021, 11:21:20 pm by TinkeringTomas »
Online ataradov
    • Personal site
« Reply #4 on: November 13, 2021, 11:31:45 pm »
This is a fresh crystal that is supposed to be SMD, but never was. I would assume this is a reject or a line pull, I see no reason to make this device as a standalone unit.
The length itself is irrelevant, it would not cause any issues. But the questionable origin of this crystal probably warrants a replacement. It is not likely to help with your issue, but who knows. It is worth a try.
Alex
Offline coromonadalix
« Reply #5 on: November 14, 2021, 12:44:51 am »
If the adapter work, just leave it that way
The following users thanked this post: Bassman59, Hamelec
Offline magic
« Reply #6 on: November 14, 2021, 07:40:18 am »
They ran out of THT crystals or got a deal on SMD crystals fraction of a penny cheaper ::)
I have seen a similar thing: the footprint was for a cylindrical can crystal but they bodged HC49 in there, flying 2cm above the board on the full length of its leads because it wouldn't fit normally.
Offline Zero999
  • 0999
« Reply #7 on: November 14, 2021, 09:25:38 am »
Perhaps they selected the wrong PCB footprint, or accidentally ordered surface mount crystals?
Online ataradov
    • Personal site
« Reply #8 on: November 14, 2021, 05:46:54 pm »
But this crystal was never fully SMD - the legs were not bent at any point. If they were, there would be a noticeable bend near the case. Those are half made crystals.
Alex
Offline Monkeh
« Reply #9 on: November 14, 2021, 07:09:17 pm »
Shenzhen market extra good price for you, good crystal, very high quality!
Online SiliconWizard
« Reply #10 on: November 14, 2021, 07:12:09 pm »
From a reliability standpoint, it looks pretty bad. =)
