Author Topic: Yamaha Power Assist Bicycles - how to enable the motor to run?  (Read 2735 times)
Offline legacyTopic starter
« on: September 06, 2018, 07:06:57 pm »
the cables to the motor
the connector from the motor to the battery: only the red, black, and yellow wires are used
digital controller
a pic of the motor
so, I have recently found the above bicycle for sale at a super low price, but there is a reason for that: it misses the battery pack, and the connector is not very good. It sounds like the previous owner just wanted to shift it out of the door.
Anyway, paid 100 Euro for the bicycle, and now I have to understand how to make it work.
First of all, the battery pack was at 4A@25.2V, and there are three wires from the package to the motor engine: red, black, and yellow. The blue and white wires are only used by the battery charger.
I don't know what the yellow wire is for, it looks like a sort of "power good" signal or "battery good" signal, and without that wire connected, the controller on the bicycle handlebar says the battery is no good, and it doesn't enable the motor to run, even if it takes the energy from the external PSU rather than a battery pack.
Since I don't have an original battery package I can't try to investigate or reverse engineering signals.
Do you happen by any chance happen to know what is the yellow wire for? And which kind of signal (e.g. 5V DC, higher?) does the motor-box need to receive in order to be enabled?
Thanks in advance  :D
« Last Edit: September 06, 2018, 07:08:48 pm by legacy »
Offline NiHaoMike
    • Facebook Page
Re: Yamaha Power Assist Bicycles - how to enable the motor to run?
« Reply #1 on: September 06, 2018, 10:56:49 pm »
Probably just a thermistor to detect if the battery is getting too hot, especially for something quite low end. Try a 10k or 100k resistor to ground.
Online The Soulman
  • The sky is the limit!
« Reply #2 on: September 06, 2018, 11:04:39 pm »
From my experience with ebikes and nimh battery packs I can say that is most likely it.
Offline digsys
    • DIGSYS
« Reply #3 on: September 06, 2018, 11:23:49 pm »
In some countries, like OZ, the controller HAS to see pulses coming in from the pedals, usually 1-2KM/hr, before it will allow the motor to come in. Just a FYI
Offline m3vuv
« Reply #4 on: September 07, 2018, 01:13:24 am »
better asking the question on endlesphere.com forums.
Online Zero999
  • 0999
« Reply #5 on: September 07, 2018, 08:23:49 am »
I know I'm being picky but batteries are specified in Amp hours, i.e. Ah, not Amps.
A fully charged 4Ah battery will be able to provide 4A for an hour, or 1A for 4 hours before running completely flat.
The maximum battery discharge current might be higher, but it's not normally given on the name plate.
« Reply #6 on: September 07, 2018, 09:58:19 am »
digital controller
thanks, guy  :D
just a doubt, look at the picture, it seems the digital controller on the bicycle handlebar is able to show if the battery is at { 1/4, 2/4, 3/4, 4/4 } of its charge: how can show it?
I mean by which signals? directly from the 25.2V on the red and black cables (so, from a cabling done inside the motor), or *maybe* by the yellow wire?
The original battery was LiPo: how do you measure the charge status? (how much energy the battery can still provide)
When I switch-On the digital controller on the bicycle handlebar (by giving 25.2V on the red and black cable) I see all the four Leds power down, that means 0/4 of charge  :-//
« Reply #7 on: September 07, 2018, 10:02:06 am »
it's written on the plastic of the battery connector on the bicycle frame where the battery goes mounted, besides sentences written in Japanese: it explicitly says 25.2V and 4A, which is also the value of the fuse on the connector as the maximum current deliverable.
« Reply #8 on: September 07, 2018, 12:24:22 pm »
as a sort of lipo fuel gauge, it would be interesting to understand how the digital controller (or the circuit built-in with the battery package) estimates the approximate how much ‘fuel’ is left in the tank, and represents it by turning on the four LEDs, and - possibly - also it can enable or disable the motor engine accordingly.
My pure speculation, I don't believe it needs to be accurate at all, p.e. four simple signal LEDs which warns you about low battery level  :popcorn:
Online Zero999
  • 0999
« Reply #9 on: September 07, 2018, 12:37:41 pm »
Oh I see, then unless it's a typo, it will be the voltage rating of the motor and the current consumption, not the battery capacity.
Online MK14
« Reply #10 on: September 07, 2018, 12:56:26 pm »
I would have guessed the battery amp/hour would be around 20 amp/hour.
I don't know what exact model you have. But in general  ...
Every model in the Yamaha Power Assist Bicycles lineup is powered by a 500 Watt-hour Lithium-ion battery pack with a 36V output that recharges in just four hours.
Which would be around 20 Amp/hour if it was 25 Volts. Could be different, as yours could be a much older model.
https://globenewswire.com/news-release/2018/03/27/1453898/0/en/Yamaha-Announces-Power-Assist-Electric-Bicycle-Full-Specs-and-Pricing.html
« Reply #11 on: September 07, 2018, 07:16:47 pm »
Probably.
But I can't tell you more since I am not in contact with the previous owner  :-//
anyway, I am willing to open the motor-block, more pics will follow ...  :D
Offline m3vuv
« Reply #12 on: September 08, 2018, 12:12:50 am »
how many wires go into the motor 2/3 or 8?,and the colors most brushless motors are 3 phase,the phase wires are blue yellow and green,then you sometimes have hall sensor wires,normaly a thin red,blue,green,yellow and black,if the motor has 3 wires,its brushless,8 its brushless with hall sensors,and just 2 wires its a brushed motor,hope this helps,cheers m3vuv.
Offline NiHaoMike
    • Facebook Page
« Reply #13 on: September 08, 2018, 01:27:54 am »
100W doesn't sound like much when cheap Walmart specials are 300W or more nowadays. It was probably designed when battery technology was much less advanced and increasing the power would give too little range.
« Reply #14 on: September 08, 2018, 09:49:50 am »
the motor engine
let's open the motor
brushless with 3 phases
sensor for the bicycle crank
an explode of the engine
the controller (WTF is that?)
« Reply #15 on: September 08, 2018, 09:58:47 am »
so, the motor has a digital controller (DSP?), unfortunately, I can't read what is written on the top of the big squared black chip, but I really wonder WHY there are so many wires going to the interface-box (the thing with LEDs and button) on the bicycle handlebar
too many wires, really too many! one of them, the grey one is connected to the yellow wire from the battery (NTC?!?!?); and for sure a subset of these wires are for the gear.
but why the digital controller that controls the brushless doesn't just use an RS422 or RS485 to communicate with what clearly appears like an interface? It everything is embedded with motor box, why do so many wires need to go outside?
« Reply #16 on: September 08, 2018, 09:59:47 am »
as proof of concept, is it anything like this for the battery?
« Reply #17 on: September 08, 2018, 10:14:00 am »
Yup, and probably this was the reason why the bicycle needed to go and the dude shifted it out for sale for a ridiculous price. It makes sense  :D
Offline perieanuo
« Reply #18 on: September 08, 2018, 09:44:11 pm »
Exactly,you have a battery controller (bms) for 4 elements,the controller balance the charge to every element separated.ntc is more often 10k or 100k .
Envoyé de mon iPad en utilisant Tapatalk
« Reply #19 on: September 19, 2018, 04:10:47 pm »
I added a 100Kohm resistor between the yellow wire and ground, but no progress
« Reply #20 on: September 21, 2018, 10:38:32 am »
other ideas? tips?
Offline NiHaoMike
    • Facebook Page
« Reply #21 on: September 21, 2018, 01:27:12 pm »
Try 10k, which is the more common kind of NTC anyways.
