I'm still plugging away at this. I think I have enough figured out now to be able to reprogram the STM8, but I'm not committing to actually doing that yet.
This is what I have so far. If I do reprogram it, I'd have to double check all this. The Nixie driving lines appear to follow a neat pattern, and after following about the first 15, so far I have only spot checked some of the others.
One anomaly (meaning mystery to me now) is that the /OE pin of the first 595 shift register in the chain is under the control of the STM8, while the /OE pins of all the other 595s are grounded. I have not powered up the board again to see if I can catch the micro disabling the first shift register outputs.
* "NixieClock IN12 V4.2" board. September 2023
* STM8S003F3 TSSOP20 8K FLASH, 1K RAM, 128 byte eeprom.
* Pin 1 PD4 (HS) UART1_CK/TIM2_CH1/BEEP input <= SW UP & 10k R28 pullup, GND when pressed
* Pin 2 PD5 (HS) UART1_TX/AIN5 input <= SW DOWN & 10k R29 pullup, GND when pressed
* Pin 3 PD6 (HS) UART1_RX output => 1k R11 => Q2b for colon neons DS1 & DS2
* Pin 4 NRST debug connector pin 3
* Pin 5 PA1 OSCIN
* Pin 6 PA2 OSCOUT
* Pin 7 Vss GND
* Pin 8 Vcap
* Pin 9 Vdd +3.3V
* Pin 10 PA3 (HS) SPI_NSS/TIM2_CH3
* Pin 11 PB5 (T) I2C_SDA/TIM1_BKIN inout <=> DS3231 SDA & 10k R21 pullup
* Pin 12 PB4 (T) I2C_SCL/ADC_ETR output => DS3231 scl & 10k R20 pullup
* Pin 13 PC3 (HS) TIM1_CH3/[TLI]/[TIM1_CH1N] output => 1k R25 => Q4b for LEDs red
* Pin 14 PC4 (HS) TIM1_CH4/CLK_CCO/AIN2/TIM1_CH2N output => 1k R26 => Q3b for LEDs blue
* Pin 15 PC5 (HS) SPI_SCK/TIM2_CH1 output => 595 U4 sr data in & 10k R19 pullup
* Pin 16 PC6 (HS) SPI_MOSI/TIM1_CH1 output => 1k R27 => Q5b for LEDs green
* Pin 17 PC7 (HS) SPI_MISO/TIM1_CH2 output => all 595 RCLK (latch) & 10k R18 pullup
* Pin 18 PD1 (HS) SWIM debug connector pin 2
* Pin 19 PD2 (HS) AIN3/TIM2_CH3 output => all 595 SRCLK & 10k R17 pullup
* Pin 20 PD3 (HS) AIN4/TIM2_CH2/ADC_ETR output => 595 U4 /OE (all other 595 /OE grounded)
* PC5
* V
* 595 U4
* Q0 -> 2003A U5 I1, O1-> N4 0
* Q1 -> 2003A U5 I2, O2-> N4 1
* Q2 -> 2003A U5 I3, O3-> N4 2
* Q3 -> 2003A U5 I4, O4-> N4 3
* Q4 -> 2003A U5 I5, O5-> N4 4
* Q5 -> 2003A U5 I6, O6-> N4 5
* Q6 -> 2003A U5 I7, O7-> N4 6
* Q7 -> 2003A U6 I1, O1-> N4 7
* V
* 595 U7
* Q0 -> 2003A U6 I2, O2-> N4 8
* Q1 -> 2003A U6 I3, O3-> N4 9
* Q2 -> 2003A U6 I4, O4-> N3 0
* Q3 -> 2003A U6 I5, O5-> N3 1
* Q4 -> 2003A U6 I6, O6-> N3 2
* Q5 -> 2003A U6 I7, O7-> N3 3
* Q6 -> 2003A U8 I1, O1-> N3 4
* Q7 -> 2003A U8 I2, O2-> N3 5
* V
* 595 U9
* Q0 -> 2003A U8 I3, O3-> N3 6
* Q1 -> 2003A U8 I4, O4-> N3 7
* Q2 -> 2003A U8 I5, O5-> N3 8
* Q3 -> 2003A U8 I6, O6-> N3 9
* Q4 -> 2003A U8 I7, O7-> N2 0
* Q5 -> 2003A U10 I1, O1-> N2 1
* Q6 -> 2003A U10 I2, O2-> N2 2
* Q7 -> 2003A U10 I3, O3-> N2 3
* V
* 595 U11
* Q0 -> 2003A U10 I4, O4-> N2 4
* Q1 -> 2003A U10 I5, O5-> N2 5
* Q2 -> 2003A U10 I6, O6-> N2 6
* Q3 -> 2003A U10 I7, O7-> N2 7
* Q4 -> 2003A U12 I1, O1-> N2 8
* Q5 -> 2003A U12 I2, O2-> N2 9
* Q6 -> 2003A U12 I3, O3-> N1 0
* Q7 -> 2003A U12 I4, O4-> N1 1
* V
* 595 U13
* Q0 -> 2003A U12 I5, O5-> N1 2
* Q1 -> 2003A U12 I6, O6-> N1 3
* Q2 -> 2003A U12 I7, O7-> N1 4
* Q3 -> 2003A U14 I1, O1-> N1 5
* Q4 -> 2003A U14 I2, O2-> N1 6
* Q5 -> 2003A U14 I3, O3-> N1 7
* Q6 -> 2003A U14 I4, O4-> N1 8
* Q7 -> 2003A U14 I5, O5-> N1 9
* debug connector
* Pin 1 3.3V
* Pin 2 SWIM
* Pin 3 NRST
* Pin 4 GND
