Author Topic: Wireless usb  (Read 2878 times)
Offline House91320Topic starter
Wireless usb
« on: August 02, 2011, 06:29:55 pm »
Dose any one know of a wireless usb ic?
Offline Wartex
    • http://headsplosive.com
Re: Wireless usb
« Reply #1 on: August 06, 2011, 07:28:51 am »
Take a wireless USB hub apart http://ncix.com/products/?sku=48226
Offline Bored@Work
Re: Wireless usb
« Reply #2 on: August 06, 2011, 08:18:21 am »
Or leave it as it is, and just provide a USB socket in your device to plug a WI-FI stick in.
If you really need ICs, contact Ralink, Atheros, Broadcom and the like. Be warned, those ICs aren't intended for DIY usage, are hard to find in small quantities and it is hard for a hobbyist to find enough information about a chip or chipset (including firmware license) to get on running from scratch in an own design. This is a high-volume market with a lot of secrecy around it.
alm
  • Guest
Re: Wireless usb
« Reply #3 on: August 06, 2011, 08:47:12 am »
Plugging in a Wifi stick requires USB host, driver for the stick and a 802.11 and tcp/ip stack on your device. Probably only practical if you run something like embedded Linux.
