Very simple reverse protection can be done with a fuse followed by the reverse-biased rectifier diode. If the battery is connected backwards, the diode basically shorts it out across the fuse, which blows. This is crude but effective. It is designed to save the charger, not the battery, and will stress the battery a little until the fuse opens.
