I have made a homing light/follow me home light circuit which uses some capacitors to power a relay coil to keep the headlights on for about 15 seconds, but the LED wont work when the second relay is active.
The second relay does make a clack sound and the LED is hooked up to the same circuit by wont work and the LED works fine.
And should I add a diode to the coil of the second relay?
