What still isn't clear to me is whether the radiation losses are in addition to the 50% or included in the 50%, nor the % in which energy is lost as heat in resistances vs the losses due to EM radiation, nor if a 50% loss is inevitable. Some have suggested in this thread that slow charging trough an inductor can reduce the losses below that 50%, is it true?
OK, let's take this step by step with a two capacitor example.
Problem statement: We have two identical capacitors, one charged to voltage
V1, one discharged. We connect them together and wait for the system to stop changing. What is the final result?
To solve such a problem we need to state our assumptions.
Assumption #1: Charge is conserved in the system (no charge is added or removed from outside)
Assumption #2: The system eventually settles out and the voltages stop changing (the system has at least some source of dissipative loss so that it doesn't oscillate forever)
Assumption #3: The capacitance of each capacitor is constant and does not change
Assumption #4: The capacitors are ideal and have no charge leakage between their plates
Given these assumptions we can proceed.
Firstly, determine the initial charge in the system:
Q =
CV1This is merely the charge stored in the first capacitor. The second capacitor has no charge.
Secondly, determine the final voltage
V2 when the two capacitors have equalized. By assumption #1 we must have:
Q = 2
CV2Therefore:
V2 = ½
V1Thirdly, determine change in energy between the initial and final states. We have:
E1 = ½
CV1²
E2 = 2(½
CV2²) =
CV2²
But since
V2 = ½
V1, we find that:
E2 =
CV2² = ¼
CV1² = ½
E1As you can see from the working, the change in stored energy is exactly 50%. Neither 49.999% nor 50.001%, but 50% exactly. The only way to change this result is to change the assumptions.
Does that help?
