I have a B&D human-propelled electric lawn mower. It has a single horizontal spinning blade connected to the shaft of a DC motor. The 120 VAC power from the switch goes to a full wave rectifier and then to the motor, which has brushes that have to be replaced periodically. The original rectifier was 25 A, 400 V. After the first one toasted, it was replaced with another 25A, 400 V copy. After that toasted, a 35 A, 1000 V version was used. After a couple of those blew, I now have a 50 A, 1000 V version … so far, so good. The switch is a special design (SPST-NC-mom + SPST-NO-mom, sequential) that shorts the motor leads when it disconnects the AC power. I presume this is to prevent someone from being shocked from back-EMF if they should unplug it while the blade is still spinning and touch the plug pins.
Why couldn’t a brushless AC motor be used?
Mike in California
