Hi, a bit late to the party!
Can't believe nobody here hasn't just made a cm or mm long spark-gap bipolar antenna as an oscillator.
Then the capacitance of the bread-board won't even matter.
Spark gaps can go well into the 1 to 100 Ghz microwave zone.
You could even put the miniature antenna into a piece of scap tubing as a wave guide and then measure the radio noise out the other end.
I don't have the equipment for measuring anything beyond 200Mhz so hopefully somebody here can do it instead haha.
ALSO
If you put a breadboard on top of a sheet of aluminum foil that is directly connected
to the positive terminal of its own power supply an NPN based astable multivibrator will sometimes
resonate at over 100 times its natural frequency.
Don't know why this happens, and once again hopefully somebody else can try this out with superior equipment.
