Hi guys
I've been playing around with some discrete transistor logic gate circuits. However the AND gate circuit (this is a very common design found all over the internet) does not work as expected and I can't figure out why so I am hoping someone can help restore my sanity because I am pretty sure I do understand bipolar transistors, but I don't understand what is happening here
The circuit is in the attachment - see Fig A (Q1 and Q2 are BC337)
So supposedly this is an AND circuit, the LED should light, and I should get a logic 1 output at Y when both A and B are high (5V)
What actually happens is this. When A and B are low (just not connected to anything) then the LED is out and voltage at Y is 0V
For the other logic states (all measured with DMM) and using patch wires to connect A and/or B to 5V
A=5V B=0V LED Y=0V (LED is off)
A=0V B=5V Y= 2.5V (LED lights half brightness)
A=5V B=5V Y= approx 4.6V (LED is on bright)
In the condition A=0V, B=0V I can measure the voltages
Q1 Collector is 5.1V, Base is 0V, Emitter is 2.5V
Q2 Collector is 2.5V, Base is 0V, Emitter is 0V
In the conditions A=0V B=5V
Q2 Collector is 2.5V, Base is 0.75V, Emitter is 2.3V LED is on
So somehow Q1 turns on even when the base is 0V
Ahhh so I know what may say, the base connections are floating, even though my meter says they are 0V but let's make sure they are not floating - see Fig 2 (ignore the dashed line ad 390R resistor for now)
And guess what? Adding the 10K from base to ground makes no difference
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
So I remove Q1 and test it in my DCA55 - it is fine. But I replace it with a new one anyway - no difference
Then I think it may be something stupid with the veroboard (tracks not cut properly) but I can't find any problem there
But not to be deterred, I then built the same circuit again on another patch of the veroboard using new components and this time I used S8050 transistors. Guess what? No difference.
So I then tried adding a resistor (the one in dotted lines on Fig 2) and the brightness of the LEd reduces when A is low and B is high. Once I get down to 390R, the LED no longer lights apart from when both A and B are High (5V) when the logical AND is true and it lights brightly.
But really the logic gate still isn't actually working.
When A is 0V and B is 5V the output at Y should be below a logic 0 threshold (<0.8V seems acceptable for 5V logic) but it isn't
What I have is
A=0V B=0V Y=0V
A=0V B=5V Y=1.2V (indeterminate logic level)
A=5V B=0V Y=0V
A=5V B=5V Y=4.6V (acceptable logic 1)
Using ohms law this actually tells me that the current 'leaking' through Q1 when base = 0V and it is supposed to be turned off is 1.2/390 = 3mA and this ties in perfectly with the half lit LED
I'm gonna try the same thing tomorrow using a couple of N channel Mosfets so I can see what that does, out of interest
In the mean time can someone please explain 1 - why the circuit does not work as expected and 2 - how to actually make an AND gate out of two transistors that actually works?
Thanks
Rich
