Hey everyone,
I'm working on a little project using Silicon Labs si4712 and si4705 chips (fm tx and rx). I have things working fine, but one thing that is driving me absolutely BONKERS is the directionality of the antennas. I get *great* audio in one orientation but if I rotate the tx or rx a little, or if I'm physically near one of them, the audio starts turning to crap (usually an increase in hiss or static). These are both meant to be battery operated and one thing I've noticed is that if I do have the USB cable (charging) hooked up, things improve, presumably due to grounding?
I'm using 10cm-ish lengths of wire for the antennas and have 120nH of shunt inductance between the antenna and ground, as recommended by silabs. I've read over their documentation and to the extent that I understand it, I think I've done everything possible to correctly match the antenna to the chip. The documentation suggests that this should work fine, and my layout and grounding and supply bypassing should all be up to snuff. Their tech support has been pretty good, but tight-lipped; they say as long as I've followed their recommendations then things should be good.
Their tx output/rx input is high impedance and have an internal varactor which is automatically adjusted to match the amp/receiver to the antenna for the tuned frequency. This is different than what I'm used to, where you want to hit a specific impedance (usually 50 ohms) and match the antenna that way. You can read back the tuning capacitance and as long as you're not slammed against one of the rails, it should be matched up properly. I'm never at one end or the other so as far as I'm able to determine, things should be great, yet this stupid directionality persists!
Does anyone have any hints or tips or perhaps areas to investigate that I mightn't have thought of? The fact that I do get great audio sometimes tells me I must be close.
