I have been searching the internet for the best in circuite IC testers for couple of weeks! all fingers pointed to the ABI 8000 plus, however, it is madly expensive by all means!
Would you please recommend a similar device that is capable of testing analog and digital ICs in circuit, fault locator, short locator, oscilloscope and other functions that the ABI system has. Or if you can recommend different devices that can do its work, especially for the in circuit IC tester.
Thank you in advanced.
