If what I'm seeing is an extension of the bobbin, that's triple-insulated wire for the secondary, and extra clearance for isolation (reinforced type is required between hazardous mains wiring and touchable SELF (safe extremely low voltage).
It could also be wires wrapped around a ferrite bead, or some sort of semiconductor or molded chunk that we need more angles on. It's not a very descriptive angle here.
