That's a question I asked a few months ago after getting some fake opamps myself and seeing countless reports of even the most mundane ICs being counterfeited.
Courtesy of AliExpress and their coupons I obtained a number of too cheap to be true opamps for virtually nothing straight from the source
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
For a good measure I also bought samples from local resellers whenever I saw suspiciously looking chips at a place I was buying anything else from. Sure enough, wherever you get them from, it's all the same junk.
I wondered whether to test them or tear them down. Since a few types I had in quantities of 10, I decided to take the "don't turn it on" route with those. What I found inside quickly convinced me that testing will be utterly boring and instant teardown is the way to go.
Now a short description of the specimens and some pr0n. Image quality isn't quite Zeptobars level but good enough for identification
NE5532I got a few to see if anything has changed since Zeptobars photographed one. Some turned out to be the same, but one was different.
Dice: 3, 659.
NE5534As far as I know, there are no fully pin-compatible substitutes for this IC. So I wondered what could they put inside? Maybe there is a Chinese implementation of this classic design? Well, maybe not. They just don't care.
Dice: 8, ANON.
LM833Another common audio opamp. Same as one of the 5532s, but bottom of the packages is different. The die looks quite funny, like a cartoon drawing.
Die: 659.
NJM4558This one is popular with guitarists for whatever reason. Can we get the genuine JRC sound from AliExpress?
I actually had two, but destroyed the other one before taking the pic. It looked much more legit than this one, only the lettering was laser etched rather than printed.
Dice: 3, 46334.
TL082Many cases reported of these behaving like LM358. What could be the reason?
Die: GI
TL071What might be inside a single version of the above? More of the same, of course.
Die: 8, 20GI
LM358If TL082 is LM358 than what is LM358?
Die: ADI6
UA741Surely no one is going to fake the old 741, right?
Die: 20GI
OP07This chip I actually bought long ago expecting to get a real one. Oh well.
Die: GI956
All in all, there isn't much rhyme or reason to it. Same part may have different dice, same die may be found in different parts, even BJT and JFET at the same time. Single opamps are realized by connecting one half of a dual die. As far as I can see, all dice implement LM358 or RC4558 topology. I will leave it as an exercise for the reader to figure out which are which
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
It could perhaps be interesting to test whether they meet the spec of LM358/RC4458, and they probably do. I suspect these are off-the-shelf products that fraudsters order without markings or as bare dice and print whatever BS on them. At scale it's probably cheaper than grinding markings off of recycled chips.
