On the left hand side of the socket on the 2nd photo there's a marking. MX J (maybe L)?Take a good magnifying glass and look for other markings.
have you traced the connectors where they are going? that can give you a clue like where's the power and ground pins, i/o signal etc. so you have better hint when you've found reference in the net.
Quote from: Mechatrommer on June 22, 2011, 10:59:12 amhave you traced the connectors where they are going? that can give you a clue like where's the power and ground pins, i/o signal etc. so you have better hint when you've found reference in the net.That will be the next step. I wanted to make sure we could get the connectors before doing any further work.
