A little late on the comments here..
I use a 12kV 30mA old school (not switching) neon sign transformer, attached to a Variac with a voltage readout (usually start around 80VAC & work up until something happens)
Also, big important things here..I use a (fused) deadman's pedal to switch the line AC, and a long insulated probe, one hand behind the back and insulated CSA or rubber boots.
Huge fan running in the garage with the door open (it is smokier than h*ll!)...not a terribly healthy project, by any means.
Wetting /misting solution is baking soda and water.. don't ask the proportions..~ 1/2 tsp in 500ml water maybe-ish??
Wood penetration varies like you wouldn't believe..depends on the wood, moisture, etc.
Leave it on a thin laminated wood too long (ie: dollar store wood boxes) & the baking soda discolors & warps the wood.
Lots of (smoggy) experimentation for sure!
Good luck & above all, be safe!!!
**edit** Also..use at least 20kV wires..please!!
