Author Topic: Insufficient Power on my Load  (Read 1437 times)
Offline DarkArrow29Topic starter
  • Country: ph
« on: September 22, 2018, 06:20:29 pm »
Hi! I have this simple circuit that activates a load, whenever the switch is pressed (shorted). When the switch is released from being pressed, the load will power down slowly. I have already put this up on a breadboard. When the load is an LED, it works! But the actual load that I will use is a 2W MP3 Decoder. The load only receives 17.4 mW (based on my schematic diagram below) but before reaching the LM317, the power is 4.11 W. How can I make the load receive at least 2W. Please help! Thank you!
Offline HB9EVI
Re: Insufficient Power on my Load
« Reply #1 on: September 22, 2018, 06:36:16 pm »
this circuit is not working like that. The switch activated transistors are a mess; either, what i recommend, switch the LM317 directly with a hardware switch, or you use a  single pnp transistor switching the base with a resistor to ground, emitter to the plus terminal of the supply - but that has to be a higher power model than a BC558; e.g. a BD140 - but that's all pretty silly for the purpose - use a switch - that's it.
The following users thanked this post: DarkArrow29
Offline Benta
« Reply #2 on: September 22, 2018, 07:53:56 pm »
And use 120 ohms for R5 and change R2 accordingly.
  • Country: ph
« Reply #3 on: September 23, 2018, 03:54:02 am »
Just made a big change, sorry. So my new simulation makes the LED light up at 4.17V. If I will replace the LED with an MP3 Decoder Module with 2W and 3.7 to 5V requirement, how can this circuit activate the said module?
Offline HB9EVI
« Reply #4 on: September 23, 2018, 08:44:58 am »
Why do you use the same silly setup again now? I told you, it's not correct like that.
The pnp transistor has to be with the emitter on the plus rail; the load on the collector, the base with a resistor and switch to ground; the npn transistor is obsolete
