Casual inspection makes it a normal fuse. It is also designated as a F2 on the PCB
And it has very normal F 250mA/250V specs
But it seems to be some rheostat-like wire-wound resistor wire?
I am wondering what the function is, it is a secondary fuse, placed behind the normal fuse (labeled F1)
The markings on one side are F 250mA/250V. But the F is inside some weird L.
And the other side has 239. Might just be a production batch number. But given the weird "rheostat" like winding, it could also mean something
It is also blown. You can see the blowout in the middle in the larger image.
I am wondering if I should replace it with a "normal" fuse of the same specs.
It comes from a Tefal Airfryer. With 250mA it is obviously not the main heat fuse. And there is little in the way of other functions, this is one of the first generation of air fryers. It rotates, there is a fan, but not even a heat contol nor timer. (there is a separate clock, when it beeps you are supposed to open the lid, and that stops the heat. The heat is not stopped at all by the device itself.
Apart from having some desire to fix the airfryer, I am also wondering what this fuse is supposed to do.
With heat wire, is it supposed to combine a function of fuse and PTC-resistor?
Surely it is not supposed to be a poly-fuse, I may not know what it is, but I do know this one is not going to reset itself.
