Author Topic: What is this type of membrane keypad called  (Read 2155 times)
Offline Alex EisenhutTopic starter
  • Place text here.
« on: March 06, 2021, 05:53:15 am »
My Commodore SX-64's keyboard became harder and harder to type on, so I opened it up to clean the contacts.
I am not sure yet where the problem lies, usually it's the carbon "pill" contacts.
But what exactly is this sheet? It's awfully thin yet seems to be a multi-layer sandwich. What is it called? Who makes this kind of stuff?
I contacted Mitsumi and they just told me they have no info on old junk vintage stuff.
Online amyk
Re: What is this type of membrane keypad called
« Reply #1 on: March 06, 2021, 10:34:06 pm »
Mylar or some other plastic sheet with silver deposition tracks. Membrane keyboard manufacturers will make it.
  • Place text here.
« Reply #2 on: March 07, 2021, 06:07:58 am »
There's no silver here, and it's too rubbery to be Mylar.
« Reply #3 on: March 07, 2021, 09:24:02 am »
It is silicone rubber, and you do get repair kits for those keyboards which have that membrane in them as a new part, as the silicone wears out and the carbon printed tracks go high resistance. however try first cleaning with a lint free cloth and gentle rubbing of the gold PCB and the black printed side with isopropyl alcohol, nothing stronger than ethyl alcohol 90% or pure isopropyl alcohol, to remove any deposited film that prevents contact. Light rubbing, as that carbon ink will be very fragile now.
  • Place text here.
« Reply #4 on: March 08, 2021, 01:53:08 am »
Yeah but I think the trouble is the set of contacts between the PCB and the membrane, it was under pressure with a metal stiffener held in place with two screws. Bad contacts there would impact all the keys, I couldn't really find a bad pill in the matrix, but this set of contacts looks bad.
But I tore it off the PCB so now I'm in trouble.
