Author Topic: What is the best PCB socket for oscilloscope  (Read 706 times)
Offline crgarciaTopic starter
  • Country: ar
« on: October 29, 2022, 10:38:28 am »
I built my first PCB (hobbyist only), and I added some 2.54mm sockets, that I often use for probing with the oscilloscope.
The problem I have is that I don't want to be holding the probe, so I usually add some wires and use the GND clip, but this creates large ground loops and add a lot of noise into the scope, which for some measurements is a problem.
What other alternative footprints/sockets/... can I use to make it easy to hook the scope, reducing ground loop/noise?
Thanks!
Offline jonpaul
Re: What is the best PCB socket for oscilloscope
« Reply #1 on: October 29, 2022, 11:00:14 am »
BNC connector, 1m Zin use Tektronix 10x probes
j
Jean-Paul  the Internet Dinosaur
Offline Someone
    • send complaints here
« Reply #2 on: October 29, 2022, 11:36:53 am »
How fancy do you want to go? Lecroy:
PK1-5MM-107
or
PK1-5MM-112
Beyond that you can do 50ohm direct with an appropriately terminated BNC/SMA/MHF/U.FL
