Author Topic: What happened to Lyontek LY68L6400 PSRAM?  (Read 1402 times)
Offline TimCambridgeTopic starter
« on: September 13, 2023, 09:00:03 pm »
Once widely available, particularly for various ESP project, it seems to have disappeared from LCSC. Did demand dry up, someone go after them for a patent violation,  Covid kill them, merge with someone else, ...
It was useful for a few MB of buffer at medium speed with a simple interface.
Thanks
Offline Benta
Re: What happened to Lyontek LY68L6400 PSRAM?
« Reply #1 on: September 13, 2023, 09:44:15 pm »
PSRAM normally only has a lifetime of a couple of years, then it's replaced by SRAM.
Plenty of 64 Mb SPI SRAMs out there:
https://www.issi.com/US/product-serial-sram-and-serial-ram.shtml
The following users thanked this post: TimCambridge
Online PCB.Wiz
« Reply #2 on: September 13, 2023, 11:25:13 pm »
Their data sheet says
The IS66/67WVS8M8FALL/BLL are integrated memory device containing 64Mb Pseudo Static Random Access Memory using a self-refresh DRAM array organized as 8M words by 8 bits.
and 'plenty' will be true in the future ?  Not sampling until Q4 2023
64M   IS66WVS8M8FALL,IS67WVS8M8FBLL      x1, x4   2.7~3.6V   104 MHz   -40 to 105°C   SOIC8   S=Q4/2023       Serial RAM
Offline Benta
« Reply #3 on: September 13, 2023, 11:39:57 pm »
So?
I'm neither PartMiner nor findchips. My link may have been suboptimal, admitted, ISSI ain't bleeding edge.
I just pointed out why PSRAM has a short lifetime.
Now it's your turn to provide something constructive, if you can.
Online PCB.Wiz
« Reply #4 on: September 14, 2023, 12:51:31 am »
I already did exactly that  8)
Live and factual device information from the web and data, for other readers.
Offline dmendesf
  • Country: br
« Reply #5 on: September 14, 2023, 02:57:54 am »
The following users thanked this post: ploxiln
Offline dmendesf
  • Country: br
« Reply #6 on: September 14, 2023, 03:12:09 am »
My mistake, it's just another PSRAM...
This one is true SRAM (no refresh pauses) but more expensive:
https://www.lcsc.com/mobile/product-detail/SRAM_Vilsion-Tech-VTI7064MSME_C139966.html
« Last Edit: September 14, 2023, 10:19:02 pm by dmendesf »
Online PCB.Wiz
« Reply #7 on: September 14, 2023, 03:27:01 am »
Interesting part.
Are you sure that is true SRAM ? It has a strange CE# limitation, seen on the PSRAM parts.
tCEM CE# low pulse width < 4 μs
Online DavidAlfa
« Reply #8 on: September 14, 2023, 05:35:14 am »
It's a normal psram, just a terribly low detailed datasheet.
4.6 Command termination
All All Reads & Writes must be completed by CE# LOW to HIGH.
This CK# rising edge is the trigger to terminate the activated wordline for the read/write and set the device into standby.
Not doing so will block internal refresh operations until the device sees the read/write wordline terminated.
« Last Edit: September 14, 2023, 01:12:51 pm by DavidAlfa »
The following users thanked this post: PCB.Wiz
Offline aeg
« Reply #9 on: September 14, 2023, 01:11:10 pm »
Another equivalent is APS6404L available from Mouser.
Interestingly, the Lyontek website still lists LY68L6400 as mass production.
The following users thanked this post: Someone, TimCambridge
Offline peter-h
« Reply #10 on: July 17, 2024, 12:00:32 pm »
And aliexpress is selling some counterfeits (which also don't work)...
You probably won't get an 8 megabyte SRAM for $1 (small qty) :) Actually I do not believe any such device exists... just spent an hour digging around. There are only PSRAMs e.g.
APS6404L-3SQN QSPI PSRAM
which you can get from Mouser, and the price is similar to the LY68 part (which seems to come only from Aliexpress nowadays). On a quick look it looks identical and even the device ID (0x0d 0x5d) is the same!
« Last Edit: July 17, 2024, 03:45:34 pm by peter-h »
