Author Topic: minimum track width for 70um boards  (Read 3950 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: August 18, 2010, 08:07:20 pm »
I'm thinking of making something with 70 um copper (2oz/sqft), will I be ok using 0.64mm traces ?
Offline DJPhil
Re: minimum track width for 70um boards
« Reply #1 on: August 18, 2010, 08:32:28 pm »
I had to do the math on that one. I believe 25mil (0.64mm) should be fine, but it really depends on your etching process. Many board houses will go down to half that, but they've got the good equipment to guarantee it works.
I just did a 1oz board with a 15mil (0.381mm) border and it came out ok even with my crappy etching skills. I had a bit of undercut in spots, mainly because I'm really sloppy with the FeCl + sponge method. I haven't finished it up yet but it looks like it'll hold up fine, and I can always coat it if I get worried.
Hope that helps. :)
  • Global Moderator
« Reply #2 on: August 18, 2010, 08:37:10 pm »
well if I ever made it in number I would probably use a board maker and might get away with 35 um copper on prototypes although I could give 70 um a go
Offline djsb
« Reply #3 on: August 18, 2010, 09:48:51 pm »
Are you using the thinner copper because it's cheaper or for some other reason?
David.
P.S DOH! Should've asked what the standard weight was before asking and read the OP message properly. Thats what you get when posting when youre tired.
« Last Edit: August 19, 2010, 08:47:04 am by djsb »
Hertfordshire,UK
University Electronics Technician, London PIC,CCS C,Arduino,Kicad, Altium Designer,LPKF S103,S62 Operator, Electronics instructor. Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime. Credited Kicad French to English translator.
Offline RayJones
    • Personal Website
« Reply #4 on: August 18, 2010, 11:14:35 pm »
isn't 2oz thicker than the usual 1oz?
Going by recent discussions with Simon, I'd say he's planning on monitoring significant currents, hence the thicker copper, hence more concern about undercutting.
Offline EEVblog
« Reply #5 on: August 19, 2010, 02:04:19 am »
25 thou is massive, no problems at all.
Dave.
  • Global Moderator
« Reply #6 on: August 19, 2010, 06:32:45 am »
correct, standard boards are 35 um (1 oz) as I'm passing 20+amps I thought 70 um would be advisable but do have SOIC/SMD parts with 0.64mm tracks, also going into a car environment I think toughest is best.
Yes I've heard undercutting is an issue with thick copper but did not know at what widths it becomes critical
