Author Topic: What automotive electrical connectors are these?  (Read 370 times)
Offline lilJohnTopic starter
« on: September 13, 2024, 02:56:46 am »
I am making custom light accessories for my car because some of the incandescent bulbs are going dim and I can't find the LED versions in warm white to look like the old incandescent bulbs.
I plan to use these components I found on AliExpress (see list) as donor housings for my custom PCBs and I couldn't manage to find what connector types / dimensions the circled ones are. This is so that I can know ahead of time if it is possible to get away doing a plain wire out, for both the PCB and possible alternative housing, to crimp on a possible male connector because I don't want to snip the car's wiring harness.
Alternatively, I could probably just replace the natural white LEDs with warm white LEDs of the same footprint and similar voltage drop but I really want an excuse to work with Al PCBs for once. :P
Also I know that I can replace the bulbs with T5s and CxW-y mm bulbs but I have a strong history of applying too much force pushing in and breaking the-manufacturer-didn't-put-enough-plasticizer-to-make-it-soft polycarbonate snap-in clips.
Attached Image Description
Here is an image that is a better representation of Image 2 I found on eBay: https://i.ebayimg.com/images/g/C~sAAOSwWp1lTaTQ/s-l1600.webp
Offline DavidKo
  • Country: cz
Re: What automotive electrical connectors are these?
« Reply #1 on: September 13, 2024, 06:57:04 am »
Edit: Sorry. It seems to be Tyco MQS.
By the way BMW like to use connectors that are produced only for them and are hard to officially buy without their approval.
« Last Edit: September 13, 2024, 07:33:54 am by DavidKo »
Offline jfiresto
« Reply #2 on: September 13, 2024, 07:35:22 am »
They look to me like they take MQS connectors from TE / AMP Germany, perhaps even one of the attached. For those, each color has a different key – which you can usually snip off if you have the wrong color for the device.
-John
The following users thanked this post: lilJohn
Offline DavidKo
  • Country: cz
Offline jfiresto
« Reply #4 on: September 13, 2024, 07:40:00 am »
Check Farnell. Would that be Newark in the U.S.?
-John
Online tooki
« Reply #5 on: September 13, 2024, 11:14:08 am »
Yes. But I think all the major distributors have them.
Just remember that some list them by the abbreviation MQS, others by the full name, Micro Quadlok. (MQS = Micro Quadlok System)
« Reply #6 on: Today at 01:13:34 am »
Hey,
Thank you all for responding!
It really helped with my search; and right now I am designing the PCB and housings to have 2-pairs of wire out with waterproof gaskets. The plan is to crimp the male connector on the two wire output. I also managed to figure out that 2a, thanks to the image @jfiresto provided:
I also bought a few connector pairs to test out the housing parts to double check if they fit.
So in summary,
1.a) unknown
1.b) as @jfiresto says, I will try snipping one side of 2.a off
2.a) 1-1718333-1
3.a) likely 9-968554-1 (possibly jfiresto compatible with 968699?), e.g. https://www.amazon.com/2-Pin-Connector-compatible-9-968554-1/dp/B0D6QTB83P
Lol, I think I also found the air sensor / turn light side indicator / general waterproof connectors with the search term you provided: https://www.corsa-technic.com/item.php?item_id=1693&category_id=357
I'll post an update as soon as I get the connectors and am able to test the fit.
I also have an additional question that I created on another thread. It is about putting a power resistor in parallel to avoid CAN bus errors. The gist of the question is because I am switching from incandescent (stock) bulbs to LEDs, whether or not a vehicle's CAN bus system will throw or generate errors if the current draw for a system is too low. So the solution would be to put a power resistor in parallel to increase the current draw. Link (edit): https://www.eevblog.com/forum/projects/(automotive-electronics)-can-bus-error-if-current-draw-for-lighting-too-low/
« Last Edit: Today at 02:33:32 am by lilJohn »
