Hey,
By the way BMW like to use connectors that are produced only for them and are hard to officially buy without their approval.
Thank you all for responding!
It really helped with my search; and right now I am designing the PCB and housings to have 2-pairs of wire out with waterproof gaskets. The plan is to crimp the male connector on the two wire output. I also managed to figure out that 2a, thanks to the image @jfiresto provided:
They look to me like they take MQS connectors from TE / AMP Germany, perhaps even one of the attached. For those, each color has a different key – which you can usually snip off if you have the wrong color for the device.
I also bought a few connector pairs to test out the housing parts to double check if they fit.
So in summary,
1.a) unknown
1.b) as @jfiresto says, I will try snipping one side of
2.a off
2.a) 1-1718333-1
3.a) likely 9-968554-1 (possibly jfiresto compatible with 968699?), e.g.
https://www.amazon.com/2-Pin-Connector-compatible-9-968554-1/dp/B0D6QTB83PCheck Farnell. Would that be Newark in the U.S.?
Yes. But I think all the major distributors have them.
Just remember that some list them by the abbreviation MQS, others by the full name, Micro Quadlok. (MQS = Micro Quadlok System)
Lol, I think I also found the air sensor / turn light side indicator / general waterproof connectors with the search term you provided:
https://www.corsa-technic.com/item.php?item_id=1693&category_id=357I'll post an update as soon as I get the connectors and am able to test the fit.
I also have an additional question that I created on another thread. It is about putting a power resistor in parallel to avoid CAN bus errors. The gist of the question is because I am switching from incandescent (stock) bulbs to LEDs, whether or not a vehicle's CAN bus system will throw or generate errors if the current draw for a system is too low. So the solution would be to put a power resistor in parallel to increase the current draw. Link (edit):
https://www.eevblog.com/forum/projects/(automotive-electronics)-can-bus-error-if-current-draw-for-lighting-too-low/
