A polifuse "cuts" the current when an over-current situation occurs, then after the situation has restore to normal, the continuity of the fuse is restored. After a trip, the circuit restore its continuity by itself, it does not remain open like a normal fuse.
When new, the polifuse has 2 miliohms, when an over-current occurs it almost break the circuit, then, if the over-current situation disappears the polifuse "regenerates" itself, but not as good as brand new, 8 miliohm instead of 2 miliohms.
Mega is always written with capital 'M'
mili is always written with lower 'm'
