I'm involved with a project that needs to make some fairly low range pressure measurements in a water tank.
The area if interest is very small (8mm ?). I've tried using a pressure tap to bring the pressure out though a small tube and to a large (proper) pressure sensor, but there are a lot of issues with getting the tap to work right -- dynamic response, clear of air bubbles... etc.
As a replacement sensor, I've thought a small microphone like this would work:
(4.5mm dia).
However I am having trouble finding any that are compatible with water. And by compatible, I mean will give me a reliable week of operation -- for $3/ea and in the situation I am working in, I can just replace them every week if need be.
I've tested most of the 4mm and 4.5mm dia microphones that are sold on Digi-Key. Attached is a copy of the excel chart of their nominal impedances measured with time after they were submerged in distilled water. You can see where they failed when the impeadances suddenly dropped out. I didn't bother to include the microphones that gave less than one day of performance.
I'm hopeful that 2 or 3 of them may meet the 1 week performance mark in a larger statistical sampling. However, I am wondering if anyone here has experience with this kind of thing? Any suggestions on hacking a microphone (or whatever) to work underwater for a week or more?
PS: The one 4mm dia microphone that are sold on digi-key as "waterproof" (
http://www.digikey.com/product-detail/en/CME-1538-100LB/102-2190-ND/2364631) is anything but. It fails within the first 10mins of being submerged -- its redeaming value is it tends to 'dry out' and function after a few hours of being pulled out.
