Author Topic: which transfer function of RC servo i should belive ?  (Read 588 times)
Offline ammjyTopic starter
  • Country: kr
« on: April 11, 2018, 07:42:33 am »
Hello ! Thanks you for click !!
in Matlab R2017b, with System Identification toolbox, i got transfer fucntion of RC servo motor.
im using Arduino Due now. i gave signal 0 to 90 degree.
and i measured step response from potentiometer included in RC servo for feedback.
when 0 degree, voltage level is almost 0.3 V from potentiometer.
when 90 degree, voltage level is almost 1.41 V from potentiometer.
from measured excel data in workspace in matlab, i deleted value as much as 0.3 for zero matching when degree is 0.
after save input and output.
in System identification toolbox, i loaded input, output data. (when i setting input and  output, i setted starting time 0, sample time 1)
then, with process model, i got transfer function with this form.
K*exp(-Td*s)
1+Tp1*s
i repeated this process few time for do compare results.
and i stucked. because, i don't have idea. which TF i should belive....
Please, see the picture what i uploaded...
Please, give me advise, let me know..
this is my code in matlab. (time setting is fine ?)
clc; clear all; close all;                                    %Reset all
a=arduino('COM4','Due','Libraries','Servo');   %Set Arduinio board
ai_pin='A6';                                                    %Set Analog pin for ADC from potentiometer of RC Servo
s = servo(a, 'D7');
tic;        %Set stopwatch timer
i=0;
while (toc<4)
    i=i+1;
    t(i)=toc;
    out(i)=readVoltage(a,ai_pin);                    %Already adc voltages calculated
    figure(1)
    plot(t,out,'r');
    pause(0.05);
    if toc < 2                                                %if toc cound is less then 2, give 0 degree signal. if not, give 90 degree signal.
    in(i) = 0;
    writePosition(s, in(i));
    else
    in(i) = 0.5;
    end
end
« Last Edit: April 11, 2018, 07:51:27 am by ammjy »
