Conrad Hoffman,in my last post I explained that fundamental is only 12MHz and that my requirment for 100MHz was out of desire to see harmonics.Yes I would now write MHz and mHz properly
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
The more I think about using non contact method,the more attractive that options becomes.At 12MHz and 4 thousand volt,like you said the field around should pretty strong,I am noob so I wonder,if I do the non contact method,how is it going change the measurement? For example,how different will freqency response be than if I measured directly? Is it going to be shifted?
Becose I know low freqency AC radiates less photons than higher freqency AC,so the 12MHz fundamental wouldn be displayed lower and high harmonics at 100MHz higher relative to their true amplitude? Is this done capacitivly or using radiowaves/photons or magneticaly by induction? How much harmonic distortion and noise would this non contact method cause,more, or less than HV probe?
