How should I look at the LTC1043 voltage divider circuits (divide by 2, etc) as a voltage source? what kind if impedance can it support?
how is this analysis done?
I figured something like 600 Hz oscillator frequency, 1uF charge on capacitor, 10k drain, so essentially the capacitor is losing X charge per second and it is restoring itself to full every 1/600th of a second? So its just a RC ripple that changes depending on load?
