Author Topic: Voltage regulator startup question  (Read 3080 times)
Offline sal_parkTopic starter
« on: January 27, 2013, 09:16:30 am »
Hi Guys,
as previously discussed on the forum I've been playing with an LM2576 voltage regulator, and now after advice here an LM2576HV version given my voltage source (battery) is 42v. I've now built up a new circuit on a breadboard which seems fine, however the startup behavior is a bit odd - I'm generally seeing a startup voltage spike of around 40 - 60v, however sometimes (1 in 20 tries) The voltage get's limited to the output voltage correctly. No changes to the circuit between the two trace outputs below and I can't find any obvious bad connections. FYI the VR is driving a 50 ohm resistor to simulate the arduino. I've attached the traces so you can see what I mean.
Which of the two traces would you describe as correct behavior of the VR ?
Any idea why I'm getting these two different startup behaviors ?
thanks
sp
edit: I've attached the diagram of the circuit I've built and the load is a 50 ohm resistor.
« Last Edit: January 27, 2013, 09:21:37 am by sal_park »
Offline Neilm
Re: Voltage regulator startup question
« Reply #1 on: January 27, 2013, 10:42:00 am »
This looks like either a layout issue or a dry joint.  I would suggest checking that the current loop is as small as possible or as low resistance as possible, see page 13 of the datasheet. Also, have you correctly checked you inductor and capacitor values and are you using a good diode. If you have "just grabbed what was lying around" you might find that this could be the issue if (for instance) the inductor is saturating. Are there any problems when it is running?
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Bored@Work
« Reply #2 on: January 27, 2013, 10:48:10 am »
As in solderless breadboard?
which seems fine,
Ah, so you think the section in the datasheet about proper layout is just for entertainment purposes and because the datasheet writer had nothing better to do than writing some more stuff?
Offline blackdog
  • Please stop pushing bullshit...
« Reply #3 on: January 27, 2013, 11:31:44 am »
Hi, Bored@Work
As always, you hit the nail in one time. :-DD
When will they learn to read the datasheets...
sal_park
NO Breadbord!!!
Use just a piece off copper clad board, build Manhattan style.
Try using a starground as much as posible.
Use good quality components, switching powersupply's eat bad components for lunch!
Picture of a 5 to 35V Switching regulator 5A, LT1074, experimenting with Coils and feedback i am testing @ the moment.
The small coil in the middle and big JH cap = extra filter, coil on the right side = commonmode filter
Kind regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
Offline ElektroQuark
    • ElektroQuark
« Reply #4 on: January 27, 2013, 07:09:09 pm »
Is this thing alive?
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #5 on: January 27, 2013, 07:38:59 pm »
how unsupportive and offensive! >:D
Offline marshallh
    • retroactive
« Reply #6 on: January 27, 2013, 07:59:01 pm »
Get some perfboard, ditch the breadboard, seriously
Verilog tips
BGA soldering intro
Offline c4757p
  • adieu
« Reply #7 on: January 27, 2013, 08:49:52 pm »
Yeah, definitely ditch the breadboard. Switchers do not like breadboards. The first and last one I tried to build on a breadboard gave a perfectly fine output - with less efficiency than a linear regulator for two minutes before it popped the transistor. Same exact circuit done Manhattan style? 87%, cool to the touch. Something was getting capacitive coupling where it wasn't good - I think between the feedback and compensation pins of the controller. The datasheet's not just being overly cautious by claiming that the layout is critical.
Offline blackdog
« Reply #8 on: January 27, 2013, 09:08:40 pm »
Hi c4757p
If you look @ my Manhattan setup, you see pin 1 & 2 bend away from the rest of the pins.
There is not only capacitive coupling but also a lot of magnetic energy from the wiring.
If your building Switchhing regulators, you have to deal with both to keep it stable.
This is also explained in various application of National Semiconductor (TI) en linear Technology.
Kind regarts,
Blackdog
Offline c4757p
  • adieu
« Reply #9 on: January 27, 2013, 09:13:38 pm »
Yep, I always do that too. Thought I could get away with a lazy breadboard test once, and like most things containing the phrase "get away with" or the word "lazy", I couldn't.   :) I should have known better, too - it wasn't even a simple boost or buck or something, it was a continuous flyback...
